Another wiring question
Old Sep 5, 2020 | 08:42 PM
Traumaslave's Avatar
Traumaslave
Default Another wiring question
Dsyton 408 needs a hot, ground, and remote. Can I just connect them to the lines for my amp? @ the insert sites on the amp? Couldn't imagine having to run all the way back to the battery.
Old Sep 5, 2020 | 09:17 PM
teedoff65's Avatar
teedoff65
I just installed one and ran them back to the battery along with amps ground and power wires.
Old Sep 6, 2020 | 07:07 AM
FrenchieM's Avatar
FrenchieM
You do. It need to run them back to the battery if you have dist blocks hook them in there
Old Sep 6, 2020 | 05:34 PM
scott_0's Avatar
scott_0
most amps need a minimum of 8-10ga wiring for power and ground, you cannot take a shortcut and power the amp from the small gauge factory wiring.
Old Sep 6, 2020 | 06:38 PM
MikeTD3's Avatar
MikeTD3
A Dayton 408 dsp draws 1.5 amps on a 12v circuit. Seems to me you could just grab power from the amp wiring.
DonN
Mar 19, 2020 07:36 PM
rpmerc86
Audio Systems
Dec 11, 2017 07:47 PM
Kenbow
Audio Systems
19
Dec 10, 2017 08:16 PM
E8USMCRET
Audio Systems
Apr 24, 2017 11:29 AM
Baja38ss
Audio Systems
Feb 22, 2016 01:54 PM
