I want to know how much power can these speakers handle, I am planning to give 200w for each speaker, will they handle this power or I should go lower.
The speakers are 8 ohms and I am planning to connect the in parallel bridged to a 4 ohm SD400.4 amp.
First, is my calculation correct, and will this work with them if calculations are correct.
The speakers you mention only need 75-125 each to shine.
m
So my 800.4 amp will be too much for them will the 400.4 will be good for the setup, and do you have any experience with these speakers. If yes, I would like to know what do you think about them.
