Help with Sound system for 2019 SGS
Old Feb 17, 2021 | 12:45 PM
tmk82's Avatar
tmk82
6th Gear
Default Help with Sound system for 2019 SGS
Hi All
New member. Trying to figure out which amp fits best in the fairing of a 2019 SGS. Was considering the rockford fosgate but after reading it seems there are way better options for the money. I currently have the boom upgrade system in the front fairing and the speakers are starting to crackle. I dont have speakers in the lids. My goal is to upgrade with a really healthy and clean 4 speaker system. Not sure if Ill need new lids or if the stock ones can be cut out to fit the right setup. Would love recommendations for speaker/amp setups. Also any vendor recommandations near the central fl area for install and proper tuning of the new system would be appreciated.
Thanks in advance
Old Feb 17, 2021 | 01:48 PM
teedoff65's Avatar
teedoff65
So about any newer good amp will fit in the fairing. Lots of room in there.
If I was wanting to pay for an install, I'd def be talking to Da Funk shop in Fl. Of course they're down in Miami, but to me would be worth the drive. There are other guys on here from Fl that do installs as well, that might chime in.
If you want to do the install yourself, its not that hard....then lots of options on components.
RF and Boss makes a speaker lid kit that comes with a template to cut your stock lids. Also comes with the mounting kit and speakers, thought most ppl swap the RF speakers out for something much better.
Old Feb 17, 2021 | 07:10 PM
tmk82's Avatar
tmk82
6th Gear
Thanks for the response. Might not attempt this one in my own. What are best bang for the buck with coaxials in your opinion? I’m looking at the sd 1200.4 and I’m undecided on speakers.....
Old Feb 17, 2021 | 08:02 PM
JMJOHN's Avatar
JMJOHN
Sponsor
TMK ,, I would start with this amp from the J&M website ,,,,, Part Number:JAMP-800HC14-SGP
100% plug-n-play, tuned for the stock Harley radio flash ,,,,,
the 800w ROKKER can drive, 4, 6 or 8 total main speakers on your Harley ,,,,,
includes custom SS mounting tray, all wire harnesses and hardware ,,,
__________________
JMJOHN,,,, www.Jmcorp.com ,,,, send email direct to John@Jmcorp.com for your HD-Forums VIP Discount Promo Code.
Old Feb 17, 2021 | 08:18 PM
teedoff65's Avatar
teedoff65
Best bang for you buck is not package deals like JM or RF.
For a simple system, I would start with that 1200 amp and a pair of GZ 6.5 coax speakers and a dsp. But if you're not willing to do the install yourself, check out da funk shop...they're top notch.
Old Feb 18, 2021 | 02:52 AM
MrMetro's Avatar
MrMetro
I had a J&M system (fairing only) in my 18 SGS. Although OK, WAY better options out there.
I purchased all my components from Garage Bagger Stereo (Chris is fantastic to deal with. Customer service is A+...unlike J&M).
This is what I installed:
SD 1200.4-4
GZ 6.5 coax (2 in the fairing and 2 in the lowers)
RF DSR1
wiring harnesses from Chris as well.
it’s not cheap, but what a system. Couldn’t be happier.
Old Feb 18, 2021 | 12:28 PM
tmk82's Avatar
tmk82
6th Gear
Definitely appreciate the input. It seems the gz coax are out of stock everywhere....
also any suggestions for an amp mounting kit for the 1200.4 or will I need it?
Old Feb 18, 2021 | 12:32 PM
MrMetro's Avatar
MrMetro
Try Garage Bagger Stereo. That’s where I bought all my components. Chris is excellent. He may have stock.
SD The 1200.4 will fit easily on the existing amp tray in the batwing.
Old Feb 18, 2021 | 12:48 PM
teedoff65's Avatar
teedoff65
Try aggressive audio on FB. Better prices I think. Amp and speakers.
As for amo kit, Not a batwing guy....road glides I have the 1200 under the radio with no bracket and it sits there fine. You can get a metra wiring kit to power the amp. I think its comes with speaker wires too, but I ran my own with my own speaker wire.
Rollin
Audio Systems
14
May 14, 2020 04:54 PM
Groucho-17SGS
Audio Systems
11
Oct 22, 2019 03:38 PM
Outkast6991
Audio Systems
31
Aug 24, 2016 11:45 AM
davidw221
Audio Systems
Oct 28, 2015 07:53 AM
Dave Thorpe
2014-2024 Touring Models
Mar 31, 2014 09:42 PM
