Diamond Audio doesn’t shine
Old Jul 22, 2021 | 03:42 PM
  #41
JMJIN's Avatar
JMJIN
Originally Posted by Leo D'Angelo
So would the resulting resistance for the tweeter be 8 ohms? And the woofer be 4 ohms making the amp see 6 ohms?
So in parallel circuits the current will always flow mostly through the lower resistance circuit, and total resistance will be less than the smallest branch resistance (if you have a 4Ω circuit and add another path there can only ever be less total resistance). Imagine a 2" pipe and 1" pipe being fed from the same source. Most of the water is going to go through the 2" pipe, and adding the 1" pipe will allow more flow. The calculation for parallel circuits is 1/(1/R1 + 1/R2) so for your example it will be 1/(.25+.125) which comes out to 2.66Ω. Slightly higher than two 4Ω circuits in parallel which would be 2Ω.
sean.corcoran
Audio Systems
Sep 1, 2020 01:42 PM
billablehours
Audio Systems
Jan 26, 2020 11:01 PM
sg81
Audio Systems
33
Nov 7, 2019 07:30 PM
uplandpinter
Audio Systems
May 9, 2017 09:01 PM
harley_guy1995
Jan 20, 2013 09:31 PM
