Needed or Not
Old Jul 25, 2021 | 09:58 AM
sbeamer's Avatar
sbeamer
Default Needed or Not
So I read about the PAC sni-15. I don't see where it IS or is NOT a MUST ?
Here's a scenario. 2 speaker on factory boom, amp with adjustable gain and frequencies, with RF flash.
Do you use it or not ? Do you use BT 355 with this ? or not. What does a PAC sni-15 actually do ?
Is there a quality brand ?
Old Jul 25, 2021 | 10:17 AM
Tailwind's Avatar
Tailwind
If ur using a factory amp there is no need. Ur already connected to the amp thus a Line Out Converter would not be required.
T
Old Jul 25, 2021 | 12:39 PM
sbeamer's Avatar
sbeamer
Default boom
T
should've specified, Boom radio,w/o factory amp. sorry
Old Jul 25, 2021 | 02:29 PM
Dsm Limited's Avatar
Dsm Limited
I would use one! Using the LOC, wiring the factory speaker plugs onto it, will plug into the speaker outs on the Boom head unit and no need to mess with the factory harness. From there you use RCA into the amp. Easy peasy!
This allows for low level inputs into the amp as opposed to high level.
Old Jul 25, 2021 | 07:39 PM
Tailwind's Avatar
Tailwind
That^^^^^.
If you have a Rock or 8/2 or ? Flash then use the LOC. If u have the stock OEM flash use the BT355 as that helps with the brutal bass curve associated w that flash.
T
Old Jul 26, 2021 | 09:48 PM
sbeamer's Avatar
sbeamer
That^^^^^.
T
Is there a quality LOC out there ? The last one I used, (on a different bike), burned up. Never knew why, and was told not to use it. But I didn't have the RF flash on that one.
Old Jul 26, 2021 | 11:37 PM
Tailwind's Avatar
Tailwind
That PAC SNI 15 serves its purpose very well.
T
Ercarlson187
Audio Systems
25
Dec 5, 2020 07:35 PM
Stovetop535
Audio Systems
Mar 8, 2020 08:30 AM
FLHXSFZ
Audio Systems
13
Jan 8, 2018 08:40 AM
ScreamingSkulls
Audio Systems
Jun 29, 2013 04:27 PM
Primo
Audio Systems
Oct 7, 2011 07:07 PM
