Almost there...
Old Dec 23, 2021 | 05:05 PM
  #71
fastsoup's Avatar
fastsoup
Originally Posted by Hoyt 1911A1
The voltage is clearly shown on the oscilloscope by adding up the height of the sine wave. Also a lot of them nowadays also have a voltage readout on the side along with other pertinent info.
Oh cool...I'll look out for that when tuning.
Old Dec 23, 2021 | 08:28 PM
  #72
teedoff65's Avatar
teedoff65
Originally Posted by MikeTD3
Question.....Wouldn't one want to send a specific voltage to their speakers? Say you have an amp that puts out 250watts of clean power and your speakers are rated at 100watts, why would you send them more than they can handle?
Usually RMS is under advertised for speakers. But, as long as you test that the signal isnt distorted, you're should still be safe if you push more than whats rated.
For example, I'm pushing 275 watts to a pair of faital pro rs140's. Even though they're rated as:
  • 1.75" voice coil with fiberglass former to handle up to 200 watts RMS
Old Dec 24, 2021 | 12:17 AM
  #73
hamah's Avatar
hamah
IMO it's far more important to send an undistorted signal to the speaker than a rated voltage. This also means checking the output of the preamp or HU for distortion as amps can only make bad things worse (**** in results in amplified **** out). An o-scope can detect clipping while a DMM cannot and this is the main reason I prefer the o-scope (besides an o-scope is dead easy to use and I'm lazy AF).
Having said that, both methods suffer from the same thing. It's the measurement of a single static frequency at a specific output level.
Neither approach really has a lot of relevance when it comes to music which is dynamic in both frequency and level.
This is why I prefer to use my ears to set gains. When I use my go-to tuning tunes I can hear when music is distorted. Not just from clipping but also from mechanical distortion such as excursion. I know from experience when I set the system up this way I'm not ever going to find myself smoking voice coils or tearing cones.
It's all about staying comfortably within the performance envelope. There's no need to push everything to the max for everyday use.
Now, this is not to say I never use an o-scope. I may if one is available (especially if the owner is going to hit it hard). It gives me a place to start with the mids (and/or subs). I'll then just dial the tweets in by ear.
There's a ton of opinions and info on this out there if you want to learn more.
Again, this is my opinion. There are adherents and detractors for all 3 approaches.
Old Dec 24, 2021 | 12:41 AM
  #74
fastsoup's Avatar
fastsoup
Now, this is not to say I never use an o-scope. I will if one is available. It gives me a place to start with the mids (and/or subs). I'll then just dial the tweets in by ear.
I thought about this as well...but an easy correction (Imo which I will perform) is to set gains via 1khz test tone, then set the appropriate frequency, leave the O connected, and play a variety of songs off my playlist and see if any sources makes the amp clip. Adjust from there and then let my ears do the finishing touches.
Old Dec 24, 2021 | 01:15 AM
  #75
hamah's Avatar
hamah
you'll find it impossible to accurately detect clipping while playing music. You need a static freq and dB.
Old Dec 24, 2021 | 10:02 PM
  #76
Hoyt 1911A1's Avatar
Hoyt 1911A1
Lately I've just set my gains with the DSP EQ settings that I ride with using a 1KHz test tone and an oscilloscope. That way I'm not majorly changing the signal when I'm out on the road. Ain't blown anything up so far using that method.
Old Dec 26, 2021 | 09:46 AM
  #77
fastsoup's Avatar
fastsoup
What do you mean "not changing the signal"? I assume when riding you are listening to actual music with totally different freq.
Old Dec 26, 2021 | 05:20 PM
  #78
Hoyt 1911A1
I mean some folks will set the gains with all EQ settings flat. If you do that and then tune the EQ settings it changes the signal a bit which usually adds distortion. Yes the test tone is different from music but using that test tone with the DSP settings I ride with helps keep things from being too different so to speak.
Old Dec 26, 2021 | 09:26 PM
  #79
teedoff65's Avatar
teedoff65
You wanna set your gains with a test tone. That way its a clean signal and your gains will start out based on a clean signal.
Old Dec 27, 2021 | 01:21 AM
  #80
hamah's Avatar
hamah
No argument that starting out with a clean input signal when setting gains is important but how does using a test tone ensure that? You still need to make sure the HU is outputting a clean signal first. That signal could either be a test tone or music, depending on what method you prefer for setting your gains.
