SD paper weight
Old May 14, 2022 | 10:41 AM
qclassic's Avatar
qclassic
Default SD paper weight
I got a bad batch of the SD 800x4 this is the second one that started this sine wave ground noises this one started last week after warranty expired.
Its in the LP/F/HP switch and only 3/4 channels I ran in to the same issue on he other one they are mounted in side the bags and I was told that SD improved the internals to handle vibrations on bikes.
so I put my taramp 800x4 back in until I find something else. I got -/:k with the other one a local shop sent mine in for warranty and this been 8 months now still nothing no return calls (he probably didn’t do) a dam thing with it and I bought a new one from him to replace that bad one so I have a paper weight
at least I one to use to mock up a bracket to mount in the hd-95 inner fairing. These SD 800x 4 now$450.00.
Old May 14, 2022 | 01:00 PM
Dsm Limited's Avatar
Dsm Limited
Sorry to hear you're having troubles with yours. I know they (SD) went through some quality control issues, but thought they worked through it.
Old May 14, 2022 | 10:28 PM
qclassic's Avatar
qclassic
Do you know what they improved on the amps.
Old May 24, 2022 | 01:56 AM
qclassic's Avatar
qclassic
Keeping fingers crossed I took this SD 800x4 apart looking around for broken soldier joint because the noise sounded like a ground problem so with my fluke
multimeter I had 1 prob on the ground terminal and testing along circuit board ( I took board out) of chassis but after looking on the edge of the board there was a copper wire showing
the film was worn off from it rubbing on chassis so I put rca cover on and did a continuity test on chassis and ground terminal I had a beep so I put Tesla tape over bare copper line and redid
beep test No beep.
I might do a bench test on amp or put back in saddle bag and test.
Tesla tape
Bare copper rubbed from chassis that is a ground
HKMark23
Sep 7, 2014 05:04 PM
Blue SOG
Apr 3, 2010 08:04 PM
Buzzy204
Sep 27, 2009 06:00 PM
RANDIT
Aug 21, 2008 06:53 AM
tgaetto
May 15, 2008 08:09 PM
