CB squealing on xmit 2019 Limited
Old Dec 20, 2022 | 04:28 PM
r0de_runr's Avatar
r0de_runr
Default CB squealing on xmit 2019 Limited
I installed the CB and had the head unit flashed.
Whenever I press the ptt the other cb'ers report a loud squealing and no speech.
Checked my SWR with an ant analyzer and it was under 2:1.
Put snap-on ferrite cores on as many wires as I could inside the fairing including several on the coax.
Have not tried bonding the frame for better grounds.
Tried a different antenna.
I know what common mode current is but don't see how it's getting into the radio.
Has anyone here fought this issue on a Harley CB?
73s de N5GAN
Old Dec 20, 2022 | 04:50 PM
Ssitruc's Avatar
Ssitruc
What antenna are you using?
Can you hear other's talking?
When I added the CB, I tried a hidden antenna and had no luck with it. I could communicate with a riding buddy better by yelling.... I got a standard factory whip and put it on the light bar mount on the tour pack (like a factory set up) and right away get about a mile or so transmit and receive with the same buddy, which works for me. I have since added another mount I screw the same antenna on when the tour pack is not on the bike (mounted down low below my "slot lights" in between the saddlebag and rear fender) and it seems to work just the same there.
Best if you got a neighbor to test with, because you're not going to have range for several miles...
Old Dec 20, 2022 | 04:52 PM
MedicineBow's Avatar
MedicineBow
Two things I can think of: When they flashed the unit was it set to AM and have you tried rerouting the coax? At what point did you check the SWR? At the antenna or from the coax at the CB module?
73 and good luck.
Old Dec 20, 2022 | 08:50 PM
r0de_runr's Avatar
r0de_runr
73 and good luck.
Don't know if it was set to AM when they flashed it.
Antennas are the stock short and stock long ones.
Old Dec 24, 2022 | 02:58 PM
bson's Avatar
bson
Where did you get the CB unit from? It may not be configured for the U.S. CB bands out of the box.
Old Dec 24, 2022 | 05:37 PM
r0de_runr's Avatar
r0de_runr
At a US Harley dealership.
Old Jan 2, 2023 | 04:45 PM
r0de_runr's Avatar
r0de_runr
Follow up...
All is working fine.
Ferrite chokes on as many wires in fairing and trunk as practical. Bonded trunk mount to frame and mid frame to main frame.
1.7:1 swr, 3.80 watts output.
Skip rolling in with squelch at midrange, short HD antenna.
Greg N5GAN
Old Jan 3, 2023 | 09:53 AM
MedicineBow
Originally Posted by r0de_runr
Follow up...
Greg N5GAN
That's great. I haven't been real satisfied with mine and may look at putting in chokes and ground straps. I'm too spoiled with 2M/440 radios.
Haarley
Jul 25, 2018 10:19 AM
HDBagger93
Sep 2, 2010 06:52 AM
HilllBillly
Jun 2, 2009 01:40 PM
Casper
May 3, 2008 11:55 PM
kdietz
Oct 21, 2007 12:33 AM
