Amp install
Old Jan 4, 2023 | 12:28 AM
2011BlackGlide's Avatar
2011BlackGlide
Default Amp install
Can I split the front left and right speaker outputs coming out of my factory head unit so I have four inputs going into my amp or do I need to use the front and rear left and right outputs to go into my amp giving me four?
Old Jan 4, 2023 | 06:26 AM
chopper_man's Avatar
chopper_man
You can split them just fine, lot of folks do. Why not use the front and rears tho so you can have fade ability?
Old Jan 5, 2023 | 03:23 AM
travelingypsye's Avatar
travelingypsye
It depends on what amp you are using. For example, if using a stinger spx 700x4 you don't need to since it has a 2-4 channel input switch. If you leave it in 2 channel input, it will deliver the signal to all 4 channels. If using a sound digital amp then you will need 2 splitters to feed all 4 channels.
Depending on what flash you have, you wont have fade control. A 8/2 flash doesnt allow fade control to work.
Old Jan 5, 2023 | 06:49 AM
2011BlackGlide
I am using Kenwood KAC-M3004. I am only using the two fairing speakers so I don’t need fader capabilities. I can’t afford bag speakers or flash so I’ll keep using split front left and rights for now. It seems to be working. Unless I’ll get more power or better sound by a flash and using the rears to get four inputs?
Old Jan 5, 2023 | 07:07 AM
travelingypsye
What year bike and head unit do you have?
Old Jan 5, 2023 | 09:22 AM
2011BlackGlide
2021 Road Glide FLTRX. I believe boom gts
Old Jan 5, 2023 | 09:34 AM
travelingypsye
You need to flash the head unit. If not you are taking a chance of blowing the amp and/or speakers.
Old Jan 5, 2023 | 11:13 AM
cshocker's Avatar
cshocker
That amp doesn't take speaker level inputs. So you will have to run a line out converter (speaker input to RCA output) and then split those RCA to all 4 RCA inputs on amp. Like Gypsy said, I wouldn't do it without a flash. Find $100 and go get flashed. Don't even worry about lid speakers. You're looking at approx $1500 to add lid speakers to make it worth it while riding down the road. Spend your money on your fairing.
Find the nearest Techo Research dealer near you (not a Harley dealer): https://technoresearch.info/dealer-map/
rochman
Audio Systems
Feb 10, 2019 07:58 AM
Big trucker
Aug 22, 2018 12:06 AM
RickK
Audio Systems
May 4, 2018 09:52 AM
Mattydejr
2014-2024 Touring Models
Jan 30, 2018 12:41 PM
FLYINGBROKE
Audio Systems
59
Jul 12, 2017 06:15 PM
