Map Update Authentication Issue
Old May 28, 2024 | 12:46 PM
  #31
golfblues's Avatar
golfblues
I forgot one thing they told me to disable a pop-up blockers. I did not have one so no need but maybe you have a pop-up blocker that's blocking the file
Old May 28, 2024 | 01:08 PM
  #32
cycle7447's Avatar
cycle7447
Community Influencer
Originally Posted by TOHOG
I used 32GB flash drive
I did get a copy of invoice
I was on the blower with MOCO and they asked for proof of purchase (invoice, copy of fingerprint, photo of "no map database/dealer database" messages my first grandchild's birth date. They have elevated the situation and .......... I wait.
There are two files listed on the Update do download: one is the MA-25, with a red dot, and the Dlr POI file that has a GREEN check mark beside it. MOCO says that file shouldn't be there and may be causing the issue in that I am only getting that file and not the 11GB map file.
Hope this is large enough to explain
I can't get the map file to show a green check mark and MOCO says this is causing an issue.
Now is the question: What can they do about it?????
Both of those were there from me - nothing else to look for, so, I clicked Install and let it run.
Took some time
Old May 28, 2024 | 01:16 PM
  #33
golfblues's Avatar
golfblues
Took some time
yes but you were able to click on it. I wasn't able to and either is the op here. Something is blocking the upper file.
Old May 28, 2024 | 01:25 PM
  #34
TOHOG's Avatar
TOHOG
Well I have tried and retried. Continue to format/turn off pop-ups, turn off anti-virus, stand up, turn around, sit down. and get the same results. Download size is about 1GB.
Hope the MOCO can come up with something at some time soon..... I am sure they are swamped...
Thanks to all!!
Old May 28, 2024 | 01:29 PM
  #35
cycle7447's Avatar
cycle7447
You weren't able to click on what?
Once you get to this screen, just press the enter button on your computer. Yes, I said click the enter button. Install is already clicked (highlighted), so, press the enter button
Old May 28, 2024 | 01:40 PM
  #36
TOHOG's Avatar
TOHOG
right! there is nothing else that can be done except click on install.
It does install, takes about 4 minutes total and says "successful" now EXIT.
Old May 28, 2024 | 01:50 PM
  #37
cycle7447's Avatar
cycle7447
With that screen up - did you press the enter button? Press enter first.
Press enter to get the maps. Then, click install
Old May 28, 2024 | 01:53 PM
  #38
golfblues's Avatar
golfblues
I wasn't able to get the map update file to install. Only the POI update to my24. Went through it with HD customer service and it did not work until I followed the procedure of disabling antivirus and reformatting the usb. and starting from step one again. Believe me I'm not making this up and I know it's happening to the op too.
It only works when both files have green check marks!
Old May 28, 2024 | 01:59 PM
  #39
cycle7447's Avatar
cycle7447
I completely agree with you. From what I did, the only way to get the second file to turn green was to: Press the enter button - then the install button
Old May 28, 2024 | 02:00 PM
  #40
TOHOG's Avatar
TOHOG
it only works when both files have green check marks
SO SOMEWHERE, SOME WAY I have antivirus still on, or pop-up blocker set incorrectly.
BTW disabling pop-ups does mean BLOCKING THEM, RIGHT?
I would love to see the 2 Green checkmarks!!
