Ohms question
Old Feb 8, 2025 | 05:20 PM
golfblues's Avatar
golfblues
The key is to make sure the amp has enough power to drive lower ohm speakers....if it does they will play louder...
Old Feb 8, 2025 | 07:30 PM
golfblues's Avatar
golfblues
Originally Posted by cshocker
Awesome. How do you like the CXX’s?
the 6.5 and 5x7/6x9 are favorites of mine.
And other thing I liked about to the CXX line is the weatherproofing plus the lower cost. At the time I got them at about 20% off so so they were half the price of CHX equals.
Old Feb 10, 2025 | 03:46 PM
jlb0038's Avatar
jlb0038
Originally Posted by golfblues
I'm running a cicada 1400 amp and I have 4 ohm Arc coaxial speakers in the fairing and 2 ohm Cicada CXX69 speakers in the bags. It's a perfect balance as I don't need more power in the fairing as about 175 watts up front works with 4ohm but I run about 250+ to the rears with 2ohm and I the7 are loud at 80+ miles an hour. I had 4 ohms in the bags but I would lose them at speed. Crossovers are set at 110hz front and 130hz bags. The fade feature does come in handy to have times.
I was running the Mmats 6.5 in the fairing with Mmats 6x9s in the lids with a Hertz 4.5 600 watt amp. No dsp. Sounded great, but couldn’t hear the lids at speed. I changed out all the speakers to Cicadas. 4 ohm midbass 6.5s in rhe fairing with Cicada tweeter grills. I also went with the 2 ohm CXX 6x9s in the lids. I was planning on changing out the Hertz amp with something bigger at a later date, but even though I’m way under powered, my set up sounds great. I can hear the 6x9s at 70. I have a dsp in the box and will put it in one day, but every time I ride I tell myself don’t mess with it.
Old Feb 10, 2025 | 04:02 PM
cshocker's Avatar
cshocker
You running the CMX and RRo75?
If so, how do you like them?
Old Feb 10, 2025 | 04:46 PM
Houston_t's Avatar
Houston_t
What made you decide to go with 2ohm in the kids but not in the fairing ?
Old Feb 11, 2025 | 09:32 AM
jlb0038's Avatar
jlb0038
Yes on the tweeter grills , but the 6.5s are the CMs. I like them a lot. The sound quality is excellent They are rated for 250 watts rms, and my amp has no where near that, but they are still loud, clear and not too bright.
Old Feb 11, 2025 | 09:41 AM
jlb0038's Avatar
jlb0038
i saw one of NVS audios video's and he had mentioned putting the 2 ohm in the rear to hear them better. I wanted a project, so I picked up a set to try. I was pleasantly surprised at how much louder they were over the 4 ohm Mmats. I left the fronts 4 ohm so as not to drown out the rears. It works for me.
Old Feb 11, 2025 | 09:46 AM
cshocker's Avatar
cshocker
Yeah man, that's a good combo. The CMX are even nicer.
And you are correct, those speakers don't need a ton of power.
kloccwork419
Audio Systems
Apr 16, 2023 12:06 PM
Weezer4117
Audio Systems
Feb 9, 2022 07:36 AM
chopper_man
Audio Systems
May 5, 2020 08:19 PM
fl1996nos
Audio Systems
Feb 1, 2015 12:48 PM
harleyfxstd
Nov 6, 2011 02:22 PM
