pre-out voltage
Old Jan 28, 2013 | 03:57 PM
2000FiveOh's Avatar
2000FiveOh
Originally Posted by GLACIERPEARL
More is always better.............
100% wrong! The output voltage on a HU has nothing to do with much. It's all about what the amp needs to drive full power. Higher voltage only means that he'll need to turn the gains down. Thus achieving nothing with the higher voltage. Same HU....2 different amps...2 different gain settings. Run the high outputs into the wrong amp and you have nothing but noise. Both the amp and the HU need to be considered. To say "more is better" is uneducated and bad advice. There are amps that will drive full power at 1 volt. Others won't. A 4 volt output with right amp will outperform a 7 or 8 volt out with the wrong amp.
OP: You need to really talk to someone that knows what he's talking about. Trying to mix and match is going to keep you chasing your tail. If you want a system that's going to sound really nice you want to set it up so you're never going beyond 60 or 70%. You never want to go "bigger is better" if you don't have the right amp. The first consideration is what the amp needs to drive full power. If your amp only needs 2 volts to run at it's peak then anything above that is pure noise and you will hear it. Take your time and do some research. Doing it once will save you a ton in the long run.
Old Jan 28, 2013 | 04:04 PM
2000FiveOh's Avatar
2000FiveOh
Originally Posted by DeputyMike
Seems like most of them are only 2 volt pre-out, if that. Doesn't Sony have more higher end decks, or should I be looking at different brands?
What does your amp need to run peak? Gain adjustments are not all created equal. You need to start with your amp and work backwards unless you want to start all over again with another amp. If your amp sucks (specs) no HU will change that.
UltraNutZ's Avatar
UltraNutZ
Originally Posted by UltraNutZ
Sony has several units that are 4v outputs and in reality a lot of the newer stuff will have 4v outputs. As GP and MM pointed out, when it comes to RCAs, more is better but too much can also be detrimental. You want to stay between 4 and probably no more than 7 (you won't get 7 without a line driver).
precisely what I said..
Old Jan 29, 2013 | 08:41 AM
DeputyMike's Avatar
DeputyMike
I appreciate all the advice!
Old Jan 29, 2013 | 08:47 AM
UltraNutZ's Avatar
UltraNutZ
just so everyone knows.. It's very uncommon to find aftermarket headunits that supply or amps that require any more than 4v. 4v and 2v are the norm for both. Anything above 4, you're very hard pressed to find.
kurtv52
Electrical/Lighting/Alarm
Dec 13, 2014 12:07 AM
joe mayo
Jul 4, 2013 09:42 AM
sanlyn
Mar 20, 2011 10:28 AM
LDrider
Oct 22, 2005 11:15 AM
Ultra Dickweed
Feb 17, 2005 02:35 AM
