03 electra glide classic
a couple weeks ago I noticed a amp hid under my tour pack. looked the part # up and Harley called it a sidecar amp.
Ive read every thread in this audio section and now am completly confused as to where to go next.
don't want to spend a ton of money, don't have the patience I used to have.
Mainly listen to classic rock.
thought about leaving the rear alone and putting an amp and new speakers in the front or just better speakers up front. not even sure which size would fit.
Im not an audio guy so looking for ideas where to go from here.
Thanks in advance.
Randy
the amp is part # 76218-98, I'm sure its just hooked up to the rear speakers, when I turned down the rears so I could hear the front speakers, I couldn't hear crap at highway speed till I turned the rears back up.
probally gonna do your mix of the ss amp and polk db speakers, not sure about rear set up yet. any advice would be great. I don't understand bridging or some of the terms you gentlemen with knowledge use but I keep reading and getting a little more educated.
Thanks
Randy
The amp was part of an accessory HD sold for use on '05 and older models-since discontinued. It was sold to use with a four speaker, front/rear configuration; not just to power rear speakers.
Have you traced the wiring from the amp harness forward? If you remove the outer fairing and check the wires connected to the front speakers, you'll probably find they are part of a harness going to the back of the bike to the amp. If not, the front speakers are not connected to the amp. The only reason I would suspect for not connecting the front speakers to the amp would be if the tour pak and the attached amp were removeable in which case the front speakers would no signal from the amp with the amp removed, so a prior owner connected the front speakers to the radio rather than have no audio with the tour pak removed.
Carl
but on another note I bought some polk db521. made a huge diffrence when I installed them up front. last night I ordered the ss amp, adapter rings and polk db651 LMAO dont know if I will be able to figure out how to hook all this chit up but I think nutz said baby steps to some one so ill just start crawling.
or removing the harley amp. (its mounted to the bottom of the tour pack) and running everything off the ss 4.520.
for now gonna stay with the stock hu
i rarley listen to anything but fm sometimes listen to I heart though the aux plug.
From reading all the threads on here I understand how a lot of this is coming togeather, got the amp, speakers, adapter ring and Amp install kit ordered. Not sure which or what I need as far as RCA adapter or do I need them at all? That bracket was confusing me till you said you hammered it flat, then it made perfect scence, I was trying to figure it out as angle iron.
I hope Im making scence, I think way faster than I type.
Randy
