what's a good speaker and amp
Old Mar 21, 2013 | 05:15 PM
  #31
Hornick's Avatar
Hornick
Thanks I will let him know this. He will probably go with your set up then. Its great to be able to ask someone with the knowledge like you. I'm going to go with your set up and now can I still add bag lids with that amp or do I need another amp? I talk to bt and there controls will work with that alpine deck
Old Mar 21, 2013 | 05:23 PM
  #32
UltraNutZ's Avatar
UltraNutZ
being that the amp is a 2 ohm stable amp, and you'll be utilizing all 4 channels at 2 ohms you'd be best to add another amp for the saddlebag lids when you add them. I'm in the same boat right now with mine and awaiting the PN2.350D to run my saddlebag lids.
Can you run them, absolutely. But you would have to run them in series with the rear tour pak pods bring the impedance load the amp sees to 5.4 ohms which would drop the output power of the amp down
Old Mar 21, 2013 | 05:30 PM
  #33
Hornick's Avatar
Hornick
Where you going to put the amp when you get it?
Old Mar 21, 2013 | 05:38 PM
  #34
UltraNutZ's Avatar
UltraNutZ
well based on dimensions, it looks like it will sit right on top of the PN4.520D I currently have installed in the fairing.
Old Mar 21, 2013 | 05:43 PM
  #35
Hornick's Avatar
Hornick
That's great. Running a new power line or just a jumper to that amp?
Old Mar 21, 2013 | 05:44 PM
  #36
UltraNutZ's Avatar
UltraNutZ
oh yeah.. each amp must have it's own power..
Old Mar 23, 2013 | 02:39 PM
  #37
Hornick's Avatar
Hornick
When going with larger speakers in the fairing what are putting in for grills or just leaving the polk grills on
Old Mar 23, 2013 | 03:23 PM
  #38
UltraNutZ's Avatar
UltraNutZ
unless you're doing something special like cutting the polk grills to fit, I would simply use the stock grills.. incognito...
whiskeyfire
Audio Systems
Jul 11, 2019 07:41 AM
langwilliams
Audio Systems
11
Jun 20, 2018 06:08 AM
TBagger
Audio Systems
Mar 8, 2018 07:55 PM
ardakota
Audio Systems
Jan 4, 2017 01:50 PM
Concho
Audio Systems
Mar 25, 2015 08:33 AM
