what's a good speaker and amp
Old Mar 17, 2013 | 06:36 PM
Hornick's Avatar
Hornick
Default what's a good speaker and amp
I had OME speakers in and they sucked so I thought I'd upgrade to the boom speakers offered by HD well not much better. So I'm wondering what's a good speaker? I have a streetglide and tour pac with the speaker pods. Do I amp it then? I would like to stay with my head unit. I would like them to be nice and loud and needs some good bass. Thanks in advance
Old Mar 18, 2013 | 07:33 AM
UltraNutZ's Avatar
UltraNutZ
well you're really not going to get a whole lot of bass out of a 6.5" speaker. It will sounds tremendously better than what you have but not a ton of bass. If you want bass, you'll need to look into subwoofer options.
As for good amp and speakers, there are a ton out there and it really boils down to a couple of things; 1.) what your budget is and 2.) what you expect out of your system.
Old Mar 18, 2013 | 08:38 AM
Hornick's Avatar
Hornick
Budget is around 800. I don't need a lot of bass. I'm just looking for a all around good system. I like listening to rock if the helps.
Old Mar 18, 2013 | 09:02 AM
UltraNutZ's Avatar
UltraNutZ
If you're not concerned with fading abilities (you'll need to bring the bike to dealer to activate fader on stock radio) then I would go with
My suggestion would be
SS PN4.520D amp SS PN4.520D amp
Polk MM651 speakers Polk MM651 speakers
front and rear
Scosche LOC80 high level to RCA adapter Scosche LOC80 high level to RCA adapter
for radio
2 RCA "y" adapters
2 RCA short cables
10ga power wire (8ft)
Fuse Holder to install at battery location
Bag of polyfil from Walmart
There are varying speakers you can use, just depends on what you want to spend. Titan II, Hertz, Focal K2
Old Mar 18, 2013 | 09:11 AM
Hornick's Avatar
Hornick
Ok dumb question what's the fading? 6.5 will fit with no mod? Poly the whole outer fairing or just where the speakers go?
Old Mar 18, 2013 | 10:13 AM
Beav's Avatar
Beav
Talking
Front to back (or top to lower)
Yes... you'll need adapter rings for the uppers
Just around the speakers
System ROCKS without breaking the bank.
Beav
Old Mar 18, 2013 | 10:17 AM
Hornick's Avatar
Hornick
I'd I don't have the fading done by the dealer its going to be the same in all the speakers then?
Old Mar 18, 2013 | 11:45 AM
UltraNutZ's Avatar
UltraNutZ
that's correct sir. If you do the fading flash by the dealer then we also need to wire the inputs on the amp differently so let us know what you decide to do prior to buying anything.
Old Mar 18, 2013 | 01:08 PM
Hornick's Avatar
Hornick
I just got off the phone with the dealership. They put the tour pack on and the speakers in for me. And they said that they were pretty sure they did the fading download. I will have to check when I get home for myself. He aslo said that I have to do a download for my amp??? I have never heard of this and I have put a few car systems in. Is the amp the you suggested small enough to fit inside the fairing? Sorry for all the questions
Old Mar 18, 2013 | 01:13 PM
Hornick's Avatar
Hornick
Beav
Do you have this systems? If you do, do you have any pictures of the speakers install and the amp?
