excellent combination! make sure to wrap those speakers in the fairing with polyfil and make sure to follow the procedure to set your amp gain control.
ok can you explain on the wrapping part?? an what is the purpose of wrapping?
yes sir.
the purpose:
to fool the speaker into thinking its in a more properly tuned enclosure therefore tightening up "sloppy" bass response. Old trick that's been around since long before I was doing this professionally in the early 80s.
Is there anything you can do for the radio reception or do you have to live with it? I didn't know about this. How does harley do this with there amps?
this is not an issue with the RF amps. What he's referring to above is the Class D amps that radiates EMI. RF amp is not a Class D amp.
Thank you for all of your input. I am going to bite the bullet and go with the polk audio AA2651-A SPEAKERS:
RF AMP PBR 300X2
ARC AUDIO ADAPTER RINGS OR HAWG WIRED ADAPTER RINGS.
Lots of good suggestions and will keep reading for more input.
I will order everything this weekend after reading more.
