Cross-check
Old May 20, 2013 | 01:26 PM
jon@themccoyfamily.me's Avatar
Default Cross-check
So today after much reading and searching I ordered the following:
PN4.520
MM651 (only 1 pair)
Arc Audio Speaker Adapter Rings
10 AWG Amp kit
I am going to add another set of the MM651's in my lowers when they get it. I had to send them back due to a color issue. I am sticking with the factory head unit.
Am I missing anything for this install. I still need to order the pods for my lowers. But besides that what else should I need/do when im in there.
Thanks
Old May 20, 2013 | 01:44 PM
UltraNutZ's Avatar
UltraNutZ
you got it covered sir. You might want to take a look at the post by Gone Riding for the exact part # of the ferrite core just in case you have FM issues with the amp. They're cheap and if you have them on hand to wrap the power wires through when installing will be much easier than taking back apart.
Take a look at the sticky up top of the audio section. There's a step by step for what you're doing.
PN4.520
MM651 (only 1 pair)
10 AWG Amp kit
Thanks
Old May 20, 2013 | 01:56 PM
Harleypingman's Avatar
Harleypingman
Before asking what additional info or parts you need, simply state what you already know and the parts you already have? Why waste people's time otherwise?
Carl
Old May 20, 2013 | 02:30 PM
Thanks Ultra. I was just looking into that. Its sad for ta three dollar part they want 15 dollars to ship....
Old May 21, 2013 | 06:02 AM
NascarGuy's Avatar
NascarGuy
Don't forget the bag of rolled poly-fill from Wall world to back your speakers. It does make a difference. Also a soldering iron and some solder as well as a roll of 12 gauge wire to make leads to run from your OEM harness to the AMP. I just did my install this past weekend. I ended up getting a bad AMP with a dead rear right channel but the install itself went pretty flawlessly.
One tip I got from another poster that was helpful is plan on taking out your stock head unit so you can use the factory ground screw which is under and to the right of the head unit. Save yourself some knuckle busting and pull the head unit. Just pull the 2 screws from each side o the HU then slide it out pulling it toward the front.
Good luck with your install. Be prepared to be amazed by the difference.
Old May 21, 2013 | 08:11 PM
Hailey's Comet's Avatar
Hailey's Comet
PAC SNI-35 Line Level Converter and some short RCA cables.
Old May 21, 2013 | 08:12 PM
Hailey's Comet
Carl
How about some positive input instead of bagging on someone asking a simple question. Good grief...
Old May 25, 2013 | 08:56 AM
Thanks fella's...
Just waiting on the UPS guy now.
Brhanson75
Audio Systems
Feb 26, 2019 09:30 AM
paid4c4
Audio Systems
Oct 12, 2017 04:22 PM
danzio
Audio Systems
Jun 27, 2017 03:28 PM
mgoldade
Audio Systems
Jun 14, 2017 07:00 PM
ScrapingFloorBoards
Audio Systems
36
Mar 27, 2016 12:16 PM
