The Polk Audio MM651 speakers are what I suggest. You won't find better speakers for the money. Check post #3 for the link to Sonicelectronix, that's where I purchased mine for great price and warranty.
Thanks for the info on the Polksl Looking at their website I see 2 box like items with 3 wires coming out one side and I guess 2 from the other side. Are those needed for the installation? Or can I just plugh into the Hog Tunes amp? Also I assume I can get the adapter rings from Sonic too? As I stated before I'm audio challenged so I appreciate the help.
The two "boxes" are cross-overs for the speakers and you will need to install them. Just zip-tie them behind the horizontal fairing braces on each side once speakers are installed. Each cross-over is wired to the right and left output of the amp, I just used butt connectors and crimped. The wires coming from the other side of the cross-overs go to the speakers (white stripes are positive). I don't believe Sonicelectronix carries speaker adapters for Harley's but I used Arc Audio 6.5" adapters and other companies make them as well. Below is a link to the brand I used. Another thing too remember is that if you change amps in the future you will need a 2 ohm stable amp as the Polk MM651's are 2 ohm speakers.
