Audio system overheats
Old Aug 16, 2013 | 08:10 AM
deke's Avatar
deke
Default Audio system overheats
2010 FLHTC. Harley ipod, Harley CB, HK head unit. HK unit replaced twice by dealer, and once by extended warranty. Radio cut out, diagnosis was over heating. Solution: Rockford PBR 300x2 with Rockford T165 speakers hoping Amp would do the work not HK, Rockford Amp now cooked, overheated(Rockford replacing Amp). Everything wired correctly with proper gauge wire. Would appreciate any thoughts on possible solution short of headset listening. Do not run system excessively loud, just enough to hear clearly at 60+MPH. Radio is on at least 3 to 5 hours a day. Am considering relocating Amp to saddle bag as absolute last resort. Would appreciate any thoughts on possible solutions. Thanks....D
Old Aug 16, 2013 | 05:50 PM
UltraNutZ's Avatar
UltraNutZ
deke.. the amp is not your issue. the radio is probably not your issue either. this has bad ground or bad voltage regulator written all over it.
check your ground at your battery and where the battery attaches to the frame. make sure they're clean and snug...
Old Aug 16, 2013 | 06:40 PM
ronherman's Avatar
ronherman
I agree with UN, I ran my RF 300x2 for 10hrs a day heading to pa at a good and loud level, not a bit of a problem!
Old Aug 17, 2013 | 08:05 AM
deke's Avatar
deke
Thanks. Will go on the hunt for poor ground connection this AM. Will faulty regulator show up on multimeter as low or variable voltage? Battery is new 12/2012.
Old Aug 17, 2013 | 08:06 AM
UltraNutZ's Avatar
UltraNutZ
yes sir it will. look at the top of the electrical section there are a couple of excellent stickies on how to to test your charging system including the stator and regulator
fiddledicksr
Audio Systems
30
Mar 28, 2022 10:49 AM
Rondar
Audio Systems
Apr 11, 2019 11:03 AM
WhiskeyHarley
Oct 29, 2014 07:03 PM
Badride
Audio Systems
Jun 19, 2014 01:20 PM
dubc
May 1, 2009 09:38 AM
