Installing a newer stereo on my 2001 Flht
Old Dec 19, 2013 | 06:00 PM
sportbike1006's Avatar
sportbike1006
Default Installing a newer stereo on my 2001 Flht
Can I install a new HD stereo on my 2001 FLHT?
looking at the newer HD stereo with the CD player from a 2009 street glide
thanks
Old Dec 20, 2013 | 07:05 AM
UltraNutZ's Avatar
UltraNutZ
do you have rear speakers, passenger communications, and CB on your FLHT?
Old Dec 20, 2013 | 09:05 AM
sportbike1006
no just the stock front speakers
Old Dec 20, 2013 | 09:08 AM
UltraNutZ's Avatar
UltraNutZ
then yes sir it will plug right in for you. On the newer unit, you'll need to go into the Diagnostics menu of the radio to flip the switch on the Automatic Volume Control from what it currently is set on to the only other setting there. This flips it from digital to analog input.
Old Dec 20, 2013 | 12:26 PM
NCmc's Avatar
NCmc
Stage I
I have the same bike any idea if a radio off a 13 street glide will fit my 01 flht? Thanks
Old Dec 20, 2013 | 12:38 PM
UltraNutZ's Avatar
UltraNutZ
yes sir it will. 2006 to 2013 are all the same head units
Old Dec 20, 2013 | 12:39 PM
UltraNutZ's Avatar
UltraNutZ
and also to the OP.. Unless the 2009 model is almost free, I would look around on eBay for a newer head unit
Old Dec 20, 2013 | 01:50 PM
Iron Cross Audio's Avatar
Iron Cross Audio
Former Sponsor
Radio will need to be re-flashed for the AVC to work on the 01.
The settings in the diagnostic mode changes it from the digital signal used in 06 and later to the digital signal used in 04-05.
Prior to 04, the signal was analog and will require a re-flash.
Old Dec 20, 2013 | 01:51 PM
UltraNutZ's Avatar
UltraNutZ
ah.. my bad..
Old Dec 22, 2013 | 09:52 AM
pp6000v2's Avatar
pp6000v2
Hey ICA, I sent you a PM regarding just such an installation.
primecut
Dec 8, 2012 08:23 AM
smallsoldier
May 4, 2012 08:16 AM
shore
Nov 8, 2010 05:17 PM
Skip
Mar 1, 2008 10:26 AM
gribas
Jul 14, 2005 08:52 PM
