amp wire size
Old Apr 4, 2014 | 05:34 PM
kdawg187's Avatar
kdawg187
Default amp wire size
I'm gonna install the soundstream pn4.520 will it be ok to use 8g instead of 10g? I already have 8g and the ground to go with it and I do have a 10g fuse holder and 30 amp fuse. Can I just get a 8g fuse holder and use what I got ?
Old Apr 4, 2014 | 05:40 PM
Pioneer74's Avatar
Pioneer74
8ga will work fine.
Old Apr 4, 2014 | 08:44 PM
kdawg187's Avatar
kdawg187
Originally Posted by Pioneer74
8ga will work fine.
What size fuse? I have a fuse that has 5AG60A on it . Will this work for me?
Old Apr 4, 2014 | 08:58 PM
Pioneer74's Avatar
Pioneer74
60 amp is ok. 50 amp would be better. 40 would work. I wouldn't go below 40.
Old Apr 4, 2014 | 10:08 PM
kdawg187's Avatar
kdawg187
Thanks
Old Apr 5, 2014 | 08:00 AM
UltraNutZ's Avatar
UltraNutZ
I wouldn't put a 60a fuse on that amp. It's rated at 40A max. I always put a tad bit smaller fuse on the battery wire than the amp is rated for merely for convenience. If you put a smaller fuse, that fuse will blow before the fuse located in the amp inside your fairing blows. Pop the seat off, change the fuse, be on your way vs pulling the fairing apart to change that fuse. I've always used a 30A fuse on these amps.
Old Apr 5, 2014 | 11:43 AM
kdawg187's Avatar
kdawg187
Kool...is the round fuse holder and fuse good enough to use
Old Apr 5, 2014 | 11:59 AM
UltraNutZ's Avatar
UltraNutZ
sure.. whatever suits your needs... I use the typical ATM fuse holders you can get at AutoZone because it's the same size fuses your bike uses.
Old Apr 5, 2014 | 03:06 PM
kdawg187's Avatar
kdawg187
Sent you a PM
Old Apr 5, 2014 | 06:11 PM
UltraNutZ's Avatar
UltraNutZ
Sent you a PM
never got it
