Two questions
Old Apr 15, 2014 | 03:13 PM
Iron Cross Audio's Avatar
Iron Cross Audio
Former Sponsor
Originally Posted by WB
Both headset are not playing right speaker.
is the right channel ok with speakers??
Old Apr 15, 2014 | 06:39 PM
WB's Avatar
WB
I found the culprit. It was the rear headset. Noticed when I unplugged her headset mine played thu both speakers. I had another headset and hooked it up. Everything was good. I then hooked up my aux tunes and once again everything functioned as it should. I do appreciate you guys taking the time to help me out. Thanks again....
Old Apr 15, 2014 | 06:43 PM
WB's Avatar
WB
One more question. When not using the intercom and front and rear speakers playing should I/she be able to turn the rear speakers down/up with the tourpack volume switch? The tour pack vol switch has no effect on the volume unless it is in the intercom mode. I assume this is correct.
Old Apr 16, 2014 | 06:45 AM
UltraNutZ's Avatar
UltraNutZ
that is correct
W.P.
Aug 11, 2025 10:42 PM
hillbillywhisperer
2014-2024 Touring Models
23
Oct 11, 2016 03:42 PM
Chaser967
Apr 6, 2014 08:54 PM
Antelope138
Audio Systems
Jun 30, 2013 07:11 PM
WB
Apr 7, 2013 09:13 PM
