Problem with 2006 American Iron Horse LSC
Old Jan 9, 2010 | 07:02 PM
toolstatesmc's Avatar
toolstatesmc
6th Gear
Default Problem with 2006 American Iron Horse LSC
My AIH runs good but then suddenly it feels like it is starving for gas, choking. It does it for a couple of minutes then it will suddenly jump back to full power. It feels like it is not getting gas, but it is. The filter is clean and the carb is fine.
My other problem with it is while it is running, the starter engages and won't stop until I pull the battery cable or the plug going into the starter.
Anyone have ANY similar problems with resolution?
Old Jan 10, 2010 | 04:15 AM
FroFro24's Avatar
FroFro24
I would check all the connections throughout the ignition system, specifically the start solenoid and ignition switch.
Old Jan 10, 2010 | 09:52 AM
12pack's Avatar
12pack
I had a problem once after installing new grips with the starter engaging and I had pinched a wire from the switch on the handle bars... Just some thing to check????
Old Jan 11, 2010 | 06:25 AM
pjb's Avatar
pjb
I have a 2005 LSC. the first thing to always check is the battery terminals. they get loose and cause it to run bad.
Let me know if you need any replacement parts or accessories, I have some stuff.
Old Jan 11, 2010 | 06:26 AM
xFreebirdx's Avatar
xFreebirdx
Fuel line could have some micro cracks in it. Would be a cheap change to test.
Old Jan 11, 2010 | 08:40 AM
pjb's Avatar
pjb
flipping your fuel valve from forward to backwards (or vice versa) may remove doubts about fuel lines, tank outlets also. does it have problems running from either position?
oh, and make sure your poitive battery terminal is not shorting to ground
Old Jan 17, 2010 | 05:39 PM
DCP21's Avatar
DCP21
5th Gear
Had one in the shop similar condition, wire in the main harness under the tank a wire had pulled loose from the main plastic part of the plug. Carefully check each wire dont pull hard as you may break the tab that holds the pin in the housing, also check the wires at the ground bolt on the frame, a wire has been known on the to be holding by a strand
Old Apr 20, 2010 | 08:51 PM
toolstatesmc
6th Gear
Default 2006 Iron Horse LSC 111 SS Intermittant
My AIH problem still exists. I know a little more now after much searching.
Intermittant no spark to the rear cylinder. I start the bike and it runs fine. When I turn the bike off and restart the bike, it gets no spark to the rear cylinder. I have checked both coils, checked all wires and leads, and checked RHC controller.
I am wondering if it could be the igniter. I do not know what the igniter actually does. I know my wires from the coil go into the igniter, but it is only the rear cylinder that gets no spark.
I am looking for someone who knows something about the AIH. I am in the South Florida area and have exhausted all my local resources. Any suggestions??? I am at the point where I am thinking about posting reward posters offering $100.00 to the person who resolves this problem!
Old Apr 21, 2010 | 05:49 AM
pjb's Avatar
pjb
mine had a similar problem (05 LSC).
I replaced the coils and ignitor (ignition module). the problem kept happening until I replaced the Crank Position Sensor (CPS). it is located up front, near your oil filter, and has a wire harness that runs underneath and connects up near your battery.
let me know how that does and I'll let you know where to send the $100 to!!
oh - if you get a replacement CPS you can just run the harness up away from anything hot and to the connector near the battery. once you confirm that is the problem you can route the harness the correct way.
Old Apr 23, 2010 | 01:22 PM
toolstatesmc
6th Gear
PBJ,
Thanks for the suggestion. I have ordered the part and will keep you posted as to the results.
