Goldwing (brat/Cafe) build
Old Nov 10, 2010 | 11:13 AM
  #111
JRK5892's Avatar
JRK5892
I GOT POWER!!!!!!!!!!!!!!!!!!!!!!
Ordered and installed a new ignition harness and 0 power still... so i was done wiht it... i took out all the wiring in bike... every part! cleaned all the conections, cleaned the ground location, pulled all the wires out of the plugs and cleaned the contacts, then i ditched the jumper fuse (was the whole problem), and went with a heavy duty 8 guage fuse and soldered on all new conections... reinstalled the whole harness in the bike and BOOM! i got power!!!!!!!!
i took a light tester to the old fuse block i had tapped into the main and found out that was not making a solid conection... but now the bike is like brand new...
i have to still figure out the tail lights... brake light works great but i have no running light... but that should be easy enough to fix.. i am very very stoked... now i just have to button that all up. add some fluids, install pipes and go riding!!!!!
Old Nov 10, 2010 | 02:21 PM
  #112
Guest
Guest
Posts: n/a
...and go riding!!!!!
You missed a step, Joe. You forgot that you have to swing by so I can test-ride it for you, just to be sure it's safe and meets all quality standards...
Old Nov 13, 2010 | 08:40 AM
  #113
JRK5892's Avatar
JRK5892
ha ha ha come on by man take her for a rip!!!!
knocking more and more out nightly!!! tonight My buddy Justin came by, we cleaned up the wires a bit, then mounted the fuel and heat guage (that will be inside the tank) so that you will know where you are at on fuel and how the bike is running, also took the stock plate mount, cut that all up, welded a large washer to the end so we could slip it over the axel, and welded a piece of steel to conect it all... PLATE MOUNT DONE! (we of course will powder this sucker before it is "done"
granted they still need powder, but it is TIGHT into the shaft drive, and looks good, best of all, we are LEGAL with it mounted horiz, the cops out this way have been really cracking down on the vert mounted plates
we also had some extra time, some 1 in bar, so we decided to make up some bars for grins... here is what we came up wiht... still need to tig them in but they are pretty dope! (def not going on the goldwing but maybe one of the chops or HD's that come though)
Old Nov 13, 2010 | 02:58 PM
  #114
schumacher's Avatar
schumacher
lookin good
Old Nov 13, 2010 | 05:22 PM
  #115
JRK5892's Avatar
JRK5892
little bit of the pipe work for powder
Before
blasted:
Headers are done... Powder: high heat flat black
the mufflers are in the oven now, those are done in regular flat black (same as we have used on the rest of the bike) there is no need to use high temp on them
will get some pics up after they come out
Old Nov 13, 2010 | 07:32 PM
  #116
m i k e's Avatar
m i k e
wow sean gotter done quick huh?
hey those dyna mags are totally negociable
he said 75 but you can offer him a tad or 2 less
he aint gunna use em! when is the maiden voyage on that scoot?????
toys for tots??????
Old Nov 15, 2010 | 12:31 AM
  #117
JRK5892's Avatar
JRK5892
Mike when is that run!? prob going to take her out some time this week. Ill give oyu a shout on the mags next week as well thanks for lookingout on them
Old Nov 15, 2010 | 09:51 PM
  #118
m i k e's Avatar
m i k e
toys 4 tots is 1st sunday in december
talk @ya later
Old Nov 16, 2010 | 10:47 AM
  #119
JRK5892's Avatar
JRK5892
may work that out
long day in the shop yesterday!!! all the powder work is now completed on the G wing, got both muffler clamps done, the plate bracket (i also shaved that down so the washer was not so ugly), choke support, and mufflers
only thing that may have to be coated is after we mount the ignition the bracket that we make will ahve to be shot... but that is all! ... hope to fire her up some time this week! ... pic to come
Old Nov 17, 2010 | 09:30 AM
  #120
JRK5892's Avatar
JRK5892
my workout yesterday kicked my *** so i was pretty beat, but i had the shop all heated up and nice and warm so i went out there for a bit to get some work done
decided to install all the new powder work we did
got the new exhaust gaskets in, headers on, mufflers on, clamps nice and tight (we also powdered the sporty clamps that hold on the muffler), got the new master support on, relocated the choke cable and got that brace on, then installed the plate moutn and have that locked in... from there i added some support bolts from the top of the air box into the tool tray so that that does not bounce around with the guages mounted to it... then called it a night... hope to get fluids in her tonight and my brother and i will start to button up the wiring on her
master support
plate mount (looks much better with the shaved down washer)
header and muffler installed
close up of muffler
choke support
