Bug splatter ?
Old Mar 25, 2014 | 10:13 AM
howitzer88's Avatar
howitzer88
Dryer sheets or the 50-50 peroxide mix. I use distilled water. DO NOT use any dishwashing liquid. Will strip the wax right off.
Old Mar 25, 2014 | 02:34 PM
mtgriz's Avatar
mtgriz
What do you guys use to wet the bugged area before you work it with a dryer sheet?
Old Mar 25, 2014 | 02:39 PM
MysticTraveler's Avatar
MysticTraveler
+1 for 50/50 mix of hydrogen peroxide & water. Keep it in an opaque spray bottle. Something about peroxide makes it break down long-term if exposed to light.
Old Mar 31, 2014 | 05:14 AM
bmorebhoy's Avatar
bmorebhoy
I keep a small spray bottle of the 50/50 mix and a microfiber in my saddlebags for trips. You need to wait 3 to 5 minutes for the solution to break down the bugs. Bug guts are an acid, peroxide is a base; they interact and the guts start to dissolve.
Old Apr 1, 2014 | 03:43 PM
GeorgeH's Avatar
GeorgeH
Going to try a product called Bug Slide, supposed to help bugs not to stick so hard and easier to wash off.
Old Apr 1, 2014 | 05:14 PM
bigoil7's Avatar
bigoil7
Originally Posted by Markk9
I started using this stuff last year and it works great: www.bugslide.com
Old Apr 2, 2014 | 12:42 AM
Potato_Potato's Avatar
Potato_Potato
Originally Posted by 3itodd
peroxide and water 1/2 and 1/2 in a spray bottle! best bug remover for a $1.00 !!
I didn't believe it until I tried it!!
What he said... You can almost hear the bugs sizle... They bubble up... turn white... at which point they are pretty much liquified with no harm to the paint. Hell, you can gargle / brush your teeth with it.
hydrogen peroxide is H202 water is H20
I wondered why someone has not marketed it for that purpose — until I discovered it has a limited shelf life, especially when opened or exposed to sunlight (that is why it is sold in brown bottles) it turns to water.
You can get 2 qts @ Sam's for $4.00, if I remember right.
Dawn dishwashing detergent is an effective degreaser and wax stripper. I use once in a while to strip off wax when I do an end of the season detail but then I re-wax it.
Old Apr 5, 2014 | 08:19 PM
KDUBYA's Avatar
KDUBYA
Bugslide
martin10
Jul 19, 2018 10:09 PM
SnoRider
May 13, 2018 01:18 PM
RoadGuard
Detailing
Nov 10, 2007 06:07 AM
cdestuck
Detailing
Jan 25, 2007 01:49 AM
Wampuscat
Dec 30, 2006 11:18 AM
