68T Rear Pulley Swap
Old Oct 28, 2018 | 05:46 PM
Sisu's Avatar
Sisu
The waay too tall gearing was for EPA/MPG reasons..
Old Nov 2, 2018 | 03:08 PM
Bruce Hunt's Avatar
Bruce Hunt
So my stock 32-T and 66-T pulleys are for sale. less than 4K miles and mint cond. Also have the stock 103" cylinders, pistons (w/rings & pins) and a few other take-off parts. Message me here for contact details. Thanks, Bruce.
Old Dec 18, 2018 | 03:47 PM
Bruce Hunt's Avatar
Bruce Hunt
Can you fit a 1+1/8th " wide belt with the additional width of this rear pulley ?
Old Feb 15, 2019 | 05:13 AM
Bruce Hunt's Avatar
Bruce Hunt
Question 68 tooth rear pulley
The 68 tooth rear pulley I was able to find for my 2013 dyna is approx 1/8" in. wider than stock. Can/should I run a wider drive belt ? Any one know the part # for the wider belt ?
Old Feb 15, 2019 | 06:44 AM
Reindeer's Avatar
Reindeer
You can run the stock 1" belt on that just fine. A few others on here have done it.
Old Feb 15, 2019 | 11:29 PM
HD Bobber's Avatar
HD Bobber
absolutly, no need to get a wider belt...ran the stock one on my 30t/70t setup
Old May 2, 2019 | 01:15 PM
Bruce Hunt's Avatar
Bruce Hunt
Figured if I had room to use a 1-1/8" belt it should be approx. 10% stronger and last longer also. I have found the 1-1/8" belt in 132 T, but not 131 for my '13 FXDB. The 132 tooth should fit no problem, has any one done this ?
deadhawg
Aug 20, 2023 07:07 PM
Egarrity
Oct 30, 2014 09:02 PM
rgr357
Oct 29, 2014 03:28 PM
rotorcrazy
Apr 10, 2009 04:51 PM
