Goes into neutral from first to second
Old Dec 16, 2014 | 01:47 AM
rogersachs's Avatar
rogersachs
Question Goes into neutral from first to second
I know Harleys are hard to get into neutral, but on my 2013 Street Bob I am having the oposite problem. Started about a month ago, and has been getting worse. Have to double clutch . Tried adjusting the clutch cable and also the throw out inside of the derby cover, but no help so far.
Would appreciate help.
Roger
Old Dec 16, 2014 | 02:24 AM
loopie's Avatar
loopie
Roger
I see nothing has changed ,, your still posting silly questions
Old Dec 16, 2014 | 03:04 AM
dirtdobber's Avatar
dirtdobber
If it is a 2013 model why are you wanting to work on it yourself. You have a warranty, use it.
Old Dec 16, 2014 | 04:08 AM
wastedranger's Avatar
wastedranger
Depends on when it was bought. May have expired.
Old Dec 16, 2014 | 09:05 PM
Racqueteer9's Avatar
Racqueteer9
Ha ha ha. Good one loopie.
Old Dec 16, 2014 | 09:55 PM
loopie's Avatar
loopie
okay ill give you a serious explanation oil weight has a lot to do with it, all depends on the **** your using, 30w engine oil or 90w gearbox oil, in your gearbox
Old Dec 16, 2014 | 11:53 PM
Red Dragons's Avatar
Red Dragons
Jesus, what's with the dickish responses?
Old Dec 17, 2014 | 12:14 AM
loopie's Avatar
loopie
has a habit off asking silly questions, serious questions get a great response help from the guys here, im sorry you guys don't understand Australian humour **** take, silly question gets an silly answer
Old Dec 17, 2014 | 12:50 AM
Firewoman's Avatar
Firewoman
Roger
Did you buy the manual and are using it for your adjustments or are you just winging it?
Old Dec 17, 2014 | 08:09 AM
corliss@bakerdrivetrain.com's Avatar
Make sure your linkage is not binding between the foot control and the shift lever on the trans. The shift rod attaching the foot control to the trans needs to be parallel to the bike and free at the joints.
