Slipons and KN Air filter without any EFI mods
Old Feb 1, 2015 | 12:48 PM
Nikolaiownz's Avatar
Nikolaiownz
Default Slipons and KN Air filter without any EFI mods
So i bought my fxdb 1 years ago and was told it had PC installed.
I drove like 10000 km last year on it and this winter i discovered that there was no efi module or anything on it.
I can read that this is bad for my engine so is there anything i should check when i am doing my next service before the season starts.
ps. i had little to no truble with the bike last year - only some low idle when warm from time to time.
Cheers
Old Feb 1, 2015 | 01:00 PM
bdtaylor1979's Avatar
bdtaylor1979
If you still have the stock intake with the k&n and slip ons you should be fine. If you have a stage 1 intake then you will possibly need to add more fuel. If you aren't planning on doing any internal engine mods I would go with a set of xieds from http://sales.nightrider.com/
I've had them on 2 bikes and they work great.
Old Feb 1, 2015 | 01:10 PM
Nikolaiownz
I have the stock intake with a K&N air filter inside.. i replaced it because the one that was in when i bought the bike was all messed up and in a really bad shape.
Ok thanks.. i will check it out!
Old Feb 1, 2015 | 03:15 PM
bdtaylor1979
Your welcome. My dad has a 09 ultra with vance & hines slip ons and a k&n inside the stock intake with no fuel managment and it runs great. I think the only time you have to worry about a tuner is when you put a more open intake on.
Old Feb 2, 2015 | 05:00 AM
Warp Factor's Avatar
Warp Factor
Even if you don't see a module, the computer may still have been re-programmed.
However, lots of people run freer-flowing intake and exhaust successfully (including me) without any tuning changes or module. The computer will self-adjust to some extent.
Old Feb 2, 2015 | 09:50 AM
Thingfish's Avatar
Thingfish
Your stock EFI will adapt quite a bit, but it will still be constrained to lean parameters even with a dealer flash. EPA keeps it that way. So while it runs "OK" without anything else, it will run far better with XIEDs or a proper tuner module that can increase the fuel to air mixture. Lean is not the best condition for any bike to operate in. For $100 you might just chuck some XIEDs on there. Takes about 10 minutes and a few zip ties. Super simple. Or spend a bit more and get a real tuner, especially if you have motor mods in your future.
Old Feb 2, 2015 | 01:30 PM
DK Custom - ST's Avatar
DK Custom - ST
Platinum Sponsor
Cheers
You should be fine. However, if you choose to do any mods you may need some type of fuel management. Below is a link on EFI Options where you may find some good information as well.
https://www.hdforums.com/forum/ignit...uning-etc.html
Kelsey
__________________
Cristy
FREE SHIPPING - ORDERS OF $100 OR MORE - LOWER 48 STATES
www.DKCustom.com
Call: 662-252-8828
Text: 662-420-4891
http://i1088.photobucket.com/albums/i339/DKCustom/Links/Sig1-8-14_zps9d8aff35.jpg
Old Feb 2, 2015 | 02:59 PM
Nikolaiownz
Thanks a bunch.
I just ordered a pc3 and kn aircleaner free flow.
2018 lowrider M8
2018+ Softail Models
Mar 30, 2022 01:33 PM
afloridapi
May 13, 2016 09:39 PM
ryan9977
Apr 1, 2013 11:11 PM
ninetyzero
Dec 7, 2007 06:21 PM
Radarod66
Screamin Eagle CVO Models
May 23, 2007 12:01 AM
