sticky pedal...
Old Apr 6, 2015 | 12:01 PM
iDodgimus's Avatar
iDodgimus
Default sticky pedal...
my 07 Street Bob occasionally suffers from a sticky shifter, usually when it's hot...
when it happens, you shift down to first and the pedal stays down, it doesn't return to center... you can give it a nudge and it'll go back but that's a little more thought than i want to give to my feet while i'm riding...
anyone have any clues to a cause/remedy?
Old Apr 6, 2015 | 04:16 PM
JohnMn's Avatar
JohnMn
Factory Forwards?
Try a little oil on the moving linkage and pivot points, look for signs of rust that might be helping bind things.
If they have been too heavily oiled in the past, old oil can get gummy and collect dirt/fouling,,
I'd clean everything, look for rust and re-lube before I go looking for anything else.
Old Apr 6, 2015 | 04:24 PM
iDodgimus's Avatar
iDodgimus
factory mids... although I did replace the linkage with an aftermarket one
thanks, i automatically thought it would be inside but i'll take a look at the heim joints and clean em up tonight.
Old Apr 6, 2015 | 04:44 PM
maddghost's Avatar
maddghost
check your linkage is all inline , but take the shifter apart and clean any greasy grime that can be caught in there.
I hope it is that simple!
Old Apr 6, 2015 | 07:10 PM
dirtdobber's Avatar
dirtdobber
Take the shifter lose so you can move the shifter by hand without putting it in gear. This will check to see if the shifter is sticking.
sarpeezy
Jul 17, 2014 02:34 PM
Jucifer
Mar 10, 2012 12:21 AM
ChristoHD
Apr 6, 2011 04:17 PM
mike06train
Apr 8, 2010 02:24 PM
scaryonly
Aug 27, 2008 01:31 PM
