Troubleshooting - ECM P 1632 Code
Old Aug 7, 2019 | 06:07 AM
DCWC's Avatar
DCWC
When I was researching this issue, I noticed the negative cable to the battery was real hot. This cable was not tight against the terminal. I tightened it up, the heat stopped and I have not had this issue since.
Old Aug 7, 2019 | 09:33 AM
crusader1xxx's Avatar
crusader1xxx
Start with the basics...battery cables and charging system. More then likely it’s the battery cables..either loose, corroded or broken
Old Oct 8, 2020 | 06:18 PM
Graham Brunet's Avatar
Graham Brunet
Stage I
Try cleaning iac sensor or buying new one. I did this to mine and issue is gone
Old Nov 5, 2021 | 02:05 AM
fxdkylelowrider's Avatar
fxdkylelowrider
Stage I
im having these same problems and kinda got it from a Shady dealership idk if warranty’s gonna cover it. My compensator is going to 16 fxdl with 9000 miles had like 6300 when I got it, all stock minus the exhaust
Old Dec 18, 2021 | 09:42 PM
Angelfire36's Avatar
Angelfire36
I don't know if this is what is happening with your bike but my 2011 Dyna Street Bob started doing that after my battery went completely dead. I charged it back up but that's when the problems started. I never did figure out what the problem was, but I believe it had something to do with the battery. Check your fuses, clean them and replace if necessary, check your system relay in your fuse box. I did a load test on my battery and it checked out fine. I traded in my bike before I replaced the battery (it was time for a change anyway...). I ended up throwing a lot of parts... (new stator, voltage regulator), before I traded. battery cables both were clean and tight. FYI, now I ALWAYS put my bike on the battery tender. Lesson learned,
I got another Dyna (2014),. Let's see how this one goes.
Throw a good battery in, make sure the battery connections are good. I hope this fixes the problem!
Sharon Bailey
Feb 14, 2015 09:29 AM
cweiss
Aug 21, 2012 03:05 PM
Koppster
Sep 18, 2008 03:45 AM
X90
Aug 27, 2008 09:57 PM
bdavis385
Jun 1, 2008 10:24 PM
