Engine shuts down.. searched with no luck
Old Jun 8, 2015 | 11:01 AM
DugzKine's Avatar
DugzKine
Originally Posted by stilup
Check your relays, I had cut outs and tried changing wires, plugs and both relays. Worked for me.
Already got the new plugs and wires, so I'll look into relays. Thanks.
DugzKine's Avatar
DugzKine
Originally Posted by Punty
Do your lights cut out? Sounds Electrical of sorts. It doesn't seem like a fuel flow issue the fuel line itself holds plenty.
Lights and gauges all work.
Old Jun 8, 2015 | 11:02 AM
DugzKine's Avatar
DugzKine
Originally Posted by SIDECAR BOB
could be the lines on your fuel pump inside the tank, Harly had some problems with the fuel ines getting pinholes , riding downhill could cause air to be sucked in instead of gas. or could be the fuel pac, but since it seems to only occur going downhill, something in the fuel pick up/delivery may be a good place to start.
Sounds good. I will do some more research on this.
Old Jun 8, 2015 | 11:47 AM
nevil's Avatar
nevil
Try pulling the Fuelpak and see if the problem persists. It's an easy way to isolate that component as a cause.
Old Jun 8, 2015 | 05:50 PM
DugzKine's Avatar
DugzKine
I am concerned about running the set-up without any tuner. However, I see your point.
Old Jun 8, 2015 | 08:45 PM
nevil's Avatar
nevil
Shouldn't be a problem to use the bike without it for a couple of test runs.
Old Jun 8, 2015 | 10:51 PM
BigDogIdaho's Avatar
BigDogIdaho
My other thought is have you gone that way NOT in the morning? I realize you go opposite for the way home, but it's not the same if you understand what I'm trying to say. Where you are going down hill on way to work is up on the way home.
Old Jun 9, 2015 | 01:25 AM
DugzKine's Avatar
DugzKine
Yes I get what you're saying. It's actually 2 hills that I'm going through to and from work. I have also travelled the same route at different times of the day when taking a nice cruise and what not. The problem only happens in the cold of the morning. But I will try pulling the Fuelpak and running without it the rest of this week to see if it makes a difference. Thanks for all the suggestions everyone.
Old Aug 19, 2015 | 08:18 PM
mskirwin's Avatar
mskirwin
Check the connections at the throttle connector actuator behind the air box.
Google Harley limp mode and you will get all the information that you need.
Take the connector apart make sure all the pins are tight, put dielectric grease on the connector and see if this fixes your issue.
Old Aug 26, 2015 | 06:09 PM
DugzKine's Avatar
DugzKine
Thanks for the info. It hasn't happened in a while but I went ahead and did what you said. Hopefully the problem never comes back. I appreciate it.
RedIronHarley
Aug 17, 2017 09:47 PM
Combsie
Jul 23, 2016 06:52 PM
RickZ
Aug 7, 2015 03:04 PM
Braditude
Sep 19, 2014 04:28 AM
dinerbucket
Apr 13, 2011 09:28 PM
