help would be great
Old Jun 11, 2015 | 09:18 PM
OntarioRider's Avatar
OntarioRider
Default help would be great
So here's what happened. got on the bike after work and thought first nice day all week im going for a bit of a ride before I go home. Fired up no problem as usual. everything checked out and running perfect. I get about 400 yards down the road and everything just dies. No power at all. Coast into a parking lot and try to restart. Nothing! No lights no fuel pump completely lifeless. Tried to boost it and nothing. I turn my key to ignition and absolutely nothing. Please help me on where I should start. Its never done anything like this. Coming home from work with your ride on a flatbed sucks!
Old Jun 11, 2015 | 09:22 PM
gfroy91's Avatar
gfroy91
Check the battery. Make sure it isn't dead and that it's connected to the bike properly.
Old Jun 11, 2015 | 09:24 PM
OntarioRider
Checked all the conections I could get at on the side of the road. And tried to boost it. I couldnt even get the guage to light up.
Old Jun 11, 2015 | 09:31 PM
Huskers's Avatar
Huskers
Main bus fuse if there is one? My first thought though is battery cable or loose connection somewhere.
Old Jun 11, 2015 | 09:36 PM
golfblues's Avatar
golfblues
Loose battery cable or blown fuse. I had that happen to me but I kept blowing fuses. Turned out one of my wires coming from the Thundermax was cut by the edge of the frame and shorted out.
Old Jun 11, 2015 | 09:38 PM
OntarioRider
Ill check to see if its a fuse. And ill try searching for a bad connection to the battery. Is there a chance it could be something to do with the ignition switch itself?
Old Jun 11, 2015 | 09:49 PM
Davdoodles's Avatar
Davdoodles
I agree with other responses, when there's a sudden total dead state, it's usually a loose battery terminal or main fuse. If it's the main fuse, it might have blown because something else is wrong - usually a wire is shorting out somewhere. Have you done anything with wires (eg changed your blinkers, added an accessory plug etc) where a wire might have been pinched against bodywork, rubbed by a tire etc?
Even if the terminals are tight, try removing them, cleaning the contacts, and re-tightening (they can sometimes oxidise). If the terminals are good/tight and the main fuse looks intact, can you use a multi-meter? If so, check across the batt terminals to ensure it's got power, check across the main fuse to ensure it's still intact (sometimes fuses can look ok but still be bad) then progressively work 'outwards', checking eg that the other ends of the batt cables have good contact with the frame/ground etc...
Old Jun 11, 2015 | 09:55 PM
OntarioRider
Thanks I did do some mods to the rear signals. I got rid of the middle brake light and filled in the hole. I checked to make nothing is rubbing there but ill have a closer look. I also installed a cobra powerpro so ill check those wires as well. Probably send it to a shop I hate electrical problems
skid5665
Aug 31, 2015 07:01 PM
04stangman
May 15, 2013 11:54 AM
ResidentPirate
Apr 11, 2013 11:22 AM
usaztec66
Apr 15, 2011 02:28 AM
exemexer
Dec 30, 2010 01:50 PM
