Rusty nut on exhaust
Old Oct 3, 2015 | 10:44 AM
misfitJason's Avatar
misfitJason
Originally Posted by dirtdobber
fxdlx has a good way of protecting the inside of the tank. In cooler months it is best to keep a full tank, not necessarily so in the summer.
This helps eliminate moisture in the tank, compensation type. I have already started keeping my full. None ethanol type.
If I see rust on the studs and or nut I just clean em
He was messing with old enough. I don't think he was being serious
Old Oct 3, 2015 | 11:53 AM
fxdlx's Avatar
fxdlx
Change your exhaust studs once a year? Ya, I was messin' with him.
A little bit of truth in a joke makes it almost believable. Well it is true, I refill my gas tank when it gets empty.
Motorcycles that I store inside during the winter here I don't store with full tanks. Winter air is dry when it's below freezing. Vehichles I store outside, I fill the tanks. Like DB said in cold temps moisture in the air in an empty tank condenses to water which can f@ck things up.
Old Oct 3, 2015 | 12:27 PM
dirtdobber's Avatar
dirtdobber
Got me on that one. LOL
I only use stainless if I have to. If you do use stainless best use anti seize. The nuts are cheap to replace.
I keep plenty of the flange nuts on hand.
Old Oct 3, 2015 | 05:32 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
[QUOTE=fxdlx;14450055]Change your exhaust studs once a year? Ya, I was messin' with him.
Motorcycles that I store inside during the winter here I don't store with full tanks. Winter air is dry when it's below freezing. Vehichles I store outside, I fill the tanks. Like DB said in cold temps moisture in the air in an empty tank condenses to water which can f@ck things up.[/
I meant to say the flange nuts and not the stud bolts themselves, my bad.
apetterez
Aug 4, 2020 09:47 PM
Jwideman6207FXD
Jun 18, 2019 01:27 AM
0ut1aw
Dec 22, 2011 04:30 AM
wulffe
EVO
Aug 30, 2009 07:05 PM
SPARKY01
May 13, 2008 10:44 PM
