Foot Control & Shaft Issue
Old Nov 3, 2015 | 05:09 PM
riod34's Avatar
riod34
3rd Gear
Default Foot Control & Shaft Issue
I have an 05 Super Glide FXD for about 3 months. I've put about 1,000 miles on it since and it only has about 12,000 miles.
I started noticing the foot control lever loosing and would have to tighten the tension screw about once a week. I finally removed the lever and discovered the splines on the inside of the control and shaft were wearing. I carefully filed in between the damaged splines but cannot see just how well that worked - the only difference is that the filed areas are shiner. So I put the lever back on the shaft but when I get to tightening the tension screw the lever will not stay completely in place. The shaft naturally has a little play between the lever behind the chain case, so I'm making sure to hold/pull the shaft as far out as possible.
Can this be fixed? Do I need to replace the entire shaft and control lever? Am I missing something here?
Old Nov 3, 2015 | 08:33 PM
dyna rider's Avatar
dyna rider
Default Shifting Levers
So you have mid controls...right ?
There is a set screw on the bottom of the shift lever between the chain case and the engine block. It is a b*tch to get to and tighten, but that sounds like what you need to do.
If you have forward controls, there are 2 of the set screws that need to be tightened. Pretty sure it is a 7/32".
Old Nov 4, 2015 | 06:45 AM
DrewNJ's Avatar
DrewNJ
How are the splines on the shift lever itself? Sounds like the bolt worked loose and now the splines are worn down.
Likely going to need to replace the shift shaft and lever if both are worn down. Might get lucky that only the shifter is worn. If you have mid controls the primary will need to come completely off for the shifter shaft. If you have forwards it's just pulling the shaft.
Good luck.
Old Nov 4, 2015 | 07:18 AM
Greezey Rider's Avatar
Greezey Rider
The shift shaft is usually a harder material than the lever.
Inspect the shaft and replace the lever and you'll probably be fine, I had to replace a few levers on my old FXR, but in more than 300,000 miles, I never had to replace a shift shaft.
Old Nov 4, 2015 | 08:14 PM
riod34's Avatar
riod34
3rd Gear
Default Update
So upon inspection of the underside of the shaft.. you can see the splines are really chewed up - not just what I originally thought on the topside, which matched the wearing on the inside of the lever splines. This explains why the lever was sliding out from the underside when I'd get to really tightening the tension bolt.
But you can also see on the tension bolt (which I replaced) that the threads were getting chewed up.
I've put about 600 miles on this thing since July when I got it. Is it possible this has happened that fast? I know there have been times when I've had to hit the lever a couple times while shifting to change gears but it wasn't a constant.
Lastly, I'm an amateur, so I have no business removing the primary.. kind of wish I had forward controls for convenience but I don't really get out on long rides so mid controls work and it's my first bike. So.. what should I expect to pay the shop? I saw the OEM replacement on jandp for like $42.
I appreciate everyone's input.
Old Nov 5, 2015 | 01:50 AM
JohnMn's Avatar
JohnMn
Old Nov 6, 2015 | 07:58 AM
DrewNJ's Avatar
DrewNJ
If the bolt was loose to begin with its pretty easy to damage the splines on both pieces. That would be my guess as to what happened.
It's a bit of a job to pull the primary but not huge. I have no idea what a dealer would charge.
Going to forwards would eliminate having to pull the primary, if that's what your looking at.
Old Nov 6, 2015 | 08:12 AM
Northbound Southerner's Avatar
Most shops are going to charge you three hours plus parts and gaskets. It should work out to be about 400.00 all in...
Joe from So Cal
Aug 6, 2021 01:39 PM
tenn.vol.
Aug 26, 2016 07:02 AM
Frank the Real Biker
2014-2024 Touring Models
22
Apr 4, 2016 01:57 PM
NR5P
Jan 14, 2015 08:46 PM
Pancho25
Jun 15, 2014 12:13 AM
