tuner questions
Old Nov 15, 2015 | 01:15 AM
JohnMn's Avatar
JohnMn
Originally Posted by DK Custom
Will a bike run better with a $500 tuner than with the $100 XiED? Yes.
Will the improvement be 5 times better? No.
Is it worth it to many to pay the extra $400 to get all possible improvement? Yes.
Are tens of thousands very happy with spending only $100 and getting a much smoother accelerating, stronger accelerating bike from the XiED's? Yes.
Different strokes for different folks...or, like in my case...
I have several bikes. Some I want to get every last bit of possible power out of, and I use the Power Vision tuner.
That's Honest! Thanks Kevin.
Old Nov 15, 2015 | 10:00 AM
TJRoberto's Avatar
TJRoberto
3rd Gear
DK Custom
Thanks for all that info
One last question, would a fuelpak also help with the engines temperature. It is regulating the air and fuel mixture, or at least that's what the vance and hince fuelpak advertise.
Old Nov 15, 2015 | 10:14 AM
Warp Factor's Avatar
Warp Factor
Originally Posted by dyoungblood357
I am looking for the best bang for the buck.
Best bang for the buck, with just pipes and an air cleaner, is probably to let the bike's stock computer compensate on its own. Lots of people doing this without problems, and so am I.
Old Nov 16, 2015 | 04:29 AM
Lansing's Avatar
Lansing
The ECM can compensate until 5% of temp, Barometric pressure, airflow, etc.
When you change your exhaust, you can win 15% airflow more than stock.
The ECM can't compensate that and you lost the extra of torque and your bike don't turn round.
The only way for get power after a changing exhaust is to tune the spark advance tables.
For that you need a tuner. With modern tools we can also tune the spark advance for delete knock retard.
And i don't talk about backfiring...
Compare to a good tuner, Xied are like bandage on a wooden leg.
Some guys don't want to spend 500$ for a good tuner but are ready to buy 100$ a pair of resistors (50 cts/u) hide behind a piece of plastic.
Funny
Here the explanation by Dynojet of the VE tables job.
The VE table is the main table that models engine airflow so AFR can be accurately calculated.
This table is influenced by the camshaft, exhaust system, head design, engine displacement and air filter.
This is the most critical item that must be correct in order to make the bike run correctly.
To increase fuel make the values larger. To decrease fuel make the values smaller.
Here the VE and the Spark advance front cyl maps. Very far from a pair of resistors.
Attached Thumbnails tuner questions-table-ve.jpg   tuner questions-table-avance.jpg
Last edited by Lansing; Nov 16, 2015 at 06:31 AM. Reason: Add quote from Dynojet and Maps from WinPV
Old Nov 16, 2015 | 07:59 AM
Warp Factor
Nope. Just riding your bike from Denver to sea level requires double that 5% change (which the ECM handles automatically), and that's not even including air density changes due to variations in temperature.
Old Nov 16, 2015 | 11:08 AM
cvaria's Avatar
cvaria
Default Power vision... no real frame of reference
I just got a power vision for my bike and have been blown away by what it does/offers. i even balked at the price/value when it was held out by forum members as the next coming.
https://www.hdforums.com/forum/dyna-...-appeared.html
i like the versatility, but i'm still a novice and am being coached. night and day difference in my bike between stock mapping and after 6 rushed runs in auto tune based on a preloaded map.
the win pv provides lots of metrics to...90% of which is over my head right now, but i'll keep at it until i break something.
i really have nothing to compare it to. my sporty received the HD 1200 stage 1 download. that ran me 150. looks like theyu waived shop fees. (love lancaster hd):
so that's 150 for a 1 time use vs paying more for a tool that can be used over and over.
Old Nov 16, 2015 | 11:23 AM
Lansing's Avatar
Lansing
You'r right.
The 5% of adaptability is only for the airflow in VE tables.
Captain_Jack_Sparrow
Jul 27, 2020 06:53 AM
speedkills66
Feb 11, 2014 07:35 PM
Simon Lam
Mar 22, 2013 11:30 AM
Haxxor
Sep 5, 2012 10:38 AM
Wallace
Jun 17, 2009 08:55 PM
