Wide Glide Frame
Old Dec 12, 2015 | 10:56 AM
JONNIEROCK's Avatar
JONNIEROCK
Default Wide Glide Frame
Does anyone know if there is a difference in rake between the wide Glide and Low Rider. While looking at wide Glides it looks like the the front end on the WG is kicked out more.
Thanks Jonnierock
Old Dec 12, 2015 | 11:23 AM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
FXDWG has more rake.
Old Dec 12, 2015 | 12:42 PM
TinCupChalice's Avatar
TinCupChalice
Yep...
The Low Rider has a 30.5° head rake with 25.5" fork tubes
The Wide Glide has a 34° head rake with 27.5" fork tubes
Old Dec 13, 2015 | 06:23 PM
skinman13's Avatar
skinman13
Originally Posted by TinCupChalice
Yep...
I thought the FXDL number looked a little low so I wandered out to the garage and checked my the notes from when I rebuilt my son's 2004 FXDLI, and I have it documented as a 39mm front fork with 32 degrees rake.
Old Dec 13, 2015 | 06:47 PM
TinCupChalice
Yep, in '04 the FXDL had 39mm forks, 24.25" tubes and 32° rake, current FXDL's are showing 49mm forks, a 30.5° head rake with 25.5" fork tubes. It was '06 when HD started in with the 49mm forks and new rake...
Old Dec 14, 2015 | 07:23 AM
CuKoup's Avatar
CuKoup
My 14 FXDL shows 29° on the neck of my bike. Unless its picking up the extra 1.5° from the trees?
Old Dec 14, 2015 | 07:57 AM
Reindeer's Avatar
Reindeer
Exactly. '06+ Low Riders are the same frame as the Super Glide and Street Bob, with different trees. I think.
Old Dec 14, 2015 | 08:00 AM
CuKoup's Avatar
CuKoup
Frames are the same. The trees are different because the top tree from my LR won't line up with the set of Bob trees I got to fix my bike last winter.
cvaria
Dec 6, 2017 02:10 PM
Mr Bentwrench
Apr 4, 2014 12:33 AM
jimhaasii
Dec 3, 2012 03:35 PM
gdt3
Jan 10, 2010 01:36 PM
timberwolfz28
Aug 31, 2008 09:52 PM
