Primary stuff
Old Dec 20, 2015 | 07:36 PM
archergodwin's Avatar
archergodwin
Suede... check the splines on your inner clutch hub, closest to the IPB... I'll wager they're fractured off, about the first 3/8 of an inch or so.
That HD auto-tensioner is crap, and the overly tight chain will fracture those splines. I installed a Hayden tensioner on mine in August. ( new inner clutch hub... etc...etc. )
You've already got the SE comp sprocket, good move.
Old Dec 20, 2015 | 07:43 PM
Suede Blue Man's Avatar
Suede Blue Man
Originally Posted by monster715
You may as well pull the rest of the primary and order a bandit clutch/ billet basket and a chain final drive while your at it. You'll need to when you do a 124" build anyway
Oh, you mean this basket Did you cheat and read the last page of the book
Thanks for the heads up, I'll give it a good going over, chain was plenty tight.
Old Dec 20, 2015 | 07:59 PM
monster715's Avatar
monster715
Oh man I'm good! I need to order one of those tomorrow!
Old Dec 20, 2015 | 08:01 PM
HD Bobber's Avatar
HD Bobber
Nice mod suede. You going w/ a different clutch setup? What kind?
Old Dec 20, 2015 | 08:33 PM
Suede Blue Man
Bandit Sportsman on the way!
Yeah, I kept reading and reading, HD Pilot's primary thread, everyone's input, and it just kept coming up as a very positive update
Old Dec 20, 2015 | 08:39 PM
HD Bobber's Avatar
HD Bobber
Talking
Awesome man! You'll have one solid primary. Won't have any problems w/ slipping or getting into hear during a quick getaway.
Nicely done
Old Dec 20, 2015 | 08:55 PM
monster715's Avatar
monster715
Here now read this thread and we can follow along with a motor build too
https://www.hdforums.com/forum/dyna-...ter-build.html
Great choice on the bandit, smooth as silk, no slipping at all
Old Dec 20, 2015 | 09:01 PM
Suede Blue Man
Hahaha, that's funny man
Old Dec 20, 2015 | 09:12 PM
LunaticFringe's Avatar
LunaticFringe
it seems ridiculous that a tensioner could exert enough force on the chain to breAK Spines, only the motor create enough force to do that, sounds like the issue would be driving style or too much motor power rather than a tensioner. the tensioner & chain should have plenty of oil so it shouldn't be creating much drag on the chain. Plus the chain can't be stretching that much where the tensioner is going to change position much anyway. Maybe the tensioner pad wears and may need replaced but other than that...?
Old Dec 20, 2015 | 11:25 PM
archergodwin
Ridiculous or not Lunatic... it's what is happening, and it's happening across model lines since '07. ( when the auto-tensioner started) Don't really care if you believe it or not... I've talked to a lot of people, and read a lot of posts where this is happening. That tensioner will ratchet and lock.. it doesn't turn loose
But then again, the MoCo is great at making the stock items substandard and then convincing you to buy the "SE Performance" parts... when that's what should have come stock in the bike anyway... ie - compensator sprocket for example..
