Primary stuff
So, now the abbreviated version:
Matt, disagree with you on the tensioner, it's like an unforgiving noose, don't fool yourself, there is no holy grail of 1/8" cushion in it's spring, that's a pipe dream, an illusion, smoke and mirrors. It's like the mercy I would show a thief if I caught one in my house, non-existent.
Screw it, I'm gonna post some pics before something else happens to **** me off and then I'll add commentary after the fact.QUOTE]
Hey Suede Blue Man, let us know what amount of primary fluid you decided to fill, the 40 ounces recommended to keep the compensator lubed and living or the 14ounces recommended by Bandit so the clutch works properly and doesn't drag.
The Bandit folks use that expanding foam packing stuff so they win that hand for sure, foam packing beats a four-of-a-kind no matter how you slice it but I'd never bet against a four-of-a-kind so put that in your smoke and pipe it nonetheless
The SM states that on the second torque you torque the compensator to 175lbs, when I took mine off last night I would swear on a stack of Gideon bibles that it took much less than that to get it off and it's never been off since I bought it. It wasn't loose, no, I'm not saying that, I'm saying it was not at 175lbs torque and I've been calibrated myself since when I first joined the Army in 1980. Not saying I'm perfect or gifted or anything, just that I'm calibrated; if you pay attention in basic training you get calibrated and that's just the way it is.
So then; the clutch main nut is 1-3/16th's, so bam, off it comes, and it didn't feel like 80lbs like the book says either
So, I had to put a zip tie around the tensioner and the chain because I had zero, maybe even negative zero slack between the chain and the tensioner (you read that Matt
). The whole shebang (that's the first time I've ever written/typed "shebang"), compensator, chain/tensioner/clutch comes out without any guff, it wants to come off.
Everything looks good, all splines are clean with no cause for concern at all. The compensator sprocket shows a little rub but nothing to draw attention to itself so it will go back in, as opposed to say replacing it with the Baker Compensator. I think they have a good piece of kit there but for now I'll just run what I brung.
How's 'bout some more pics before another catastrophe hits:
Alright, so there's that.
Every aspect of the Bandit clutch is impressive - delivery time, packaging, customer service, material quality, and performace!
Only negative is the lack of instruction as to the famous "dots" to align for a perfect install, but you got that sh_t covered with previous HD Forum installers.
Looks like you are on your way, keep it coming.
Don't mess with Matt too much, he is a high level thinker
I will not purchase a new clutch, I will not purchase a new clutch, foam packaging is wasteful, philosophically this will prevent me from buying a new clutch...
Why did I open this thread!
Don't be a wuss, you know you want one
I don't have a press of my own nor know anyone with one or else I would have done it myself. They had to use a socket too to support the bearing.
