Primary stuff
Old Mar 2, 2016 | 03:52 PM
  #131
Suede Blue Man's Avatar
Suede Blue Man
TB Removed:
Old Mar 2, 2016 | 04:44 PM
  #132
mattVA's Avatar
mattVA
TB Removed:
What's the discoloration on the front cylinder. .? Intake leak?
Old Mar 2, 2016 | 06:19 PM
  #133
Suede Blue Man
My guess is from not getting hit very well from when I sprayed some of the HD silicon spray that rejuvenates the wrinkle black, I think that was some spots that say the TB concealed somewhat.
One benefit from disassembling stuff like this is you can clean and detail the hard to get places that you never can get to when it's all together.
PR's removed, one top rocker cover off at the moment.
Old Mar 2, 2016 | 06:20 PM
  #134
Reindeer's Avatar
Reindeer
Great thread. Got me pumped to finally tear into mine. Little concerned about that pulley nut though... Not afraid to drill it off, but getting it back on might be a challenge. Looks like I might have to invest in a impact, and an air compressor...
Old Mar 2, 2016 | 07:01 PM
  #135
mattVA's Avatar
mattVA
To me it looks like something else is going on. .that's like an ashen gray trailing up to the intake port. Have a look at your front intake seal.
Old Mar 2, 2016 | 08:33 PM
  #136
Suede Blue Man
Let's get jiggy with it man, that nut ain't nutting to the impact
Maybe you're right Matt but all looks in order to me on the seals and the insides of both intake tracts are exactly the same, both matching with a moistness from fuel.
I'll keep looking though and report back if I find anything
Old Mar 3, 2016 | 05:55 PM
  #137
Suede Blue Man
Present state:
Old Mar 3, 2016 | 06:24 PM
  #138
mattVA's Avatar
mattVA
Present state:
Looking good. Plug the crank case holes with rags and don't beat the piston pins out find a way to draw them free.
Old Mar 3, 2016 | 06:49 PM
  #139
HD Pilot's Avatar
HD Pilot
Nice progress! Don't lose that pr cover o-ring in the cylinder heads if you plan on reusing.
Old Mar 3, 2016 | 07:49 PM
  #140
_LostSoul_'s Avatar
_LostSoul_
Nice! You can use your old cylinder base gaskets to keep the pistons from hitting the studs. Take pics of EVERYTHING! Trust me! If your old like me, you will need them on assembly.
