Taller Kickstand ????? help
Old Jan 6, 2016 | 08:17 PM
blackbear44's Avatar
blackbear44
Default Taller Kickstand ????? help
So I have a 01 FXDXT I upgraded shocks to 14.5 Race Tech reservoir shocks
Now my kickstand is shorter so the bike leans over quite a bit. Who makes a taller kickstand ? any help is appreciated
Old Jan 6, 2016 | 08:26 PM
Greezey Rider's Avatar
Greezey Rider
Try this, I have one on mine and it works great....Here's a pic or two of mine.
http://www.bungking.com/kickstand-lift-block/
Old Jan 6, 2016 | 08:47 PM
Mchad's Avatar
Mchad
Not sure if this will work for you, but I used this on my '08 FXD when I installed 14.5" ohlins rears....
Jiffy Stand-Long" P/N 49710-94B
Old Jan 6, 2016 | 09:12 PM
sharkey's Avatar
sharkey
Wife complained of her Low Rider leaning over so far on the jiffy stand it took a lot of effort to lift the bike to vertical; I added a fraction of an inch to the top of the jiffy stand tab that locates into the slot on the frame and also fitted an oillite bushing in the swivel...now the bike sits closer to vertical when on the stand and the stand retracts cleanly and smoothly every time...pics if needed, but if you look at the stand and swivel you should be able to figure it out.
Old Jan 6, 2016 | 10:15 PM
Feileod's Avatar
Feileod
Same here, My FXDP leaned considerably in stock form when I got it. I added a 1/4" of steel to the flag that engages the frame notch. This lessened the lean angle to what I would consider normal.
Old Jan 7, 2016 | 04:15 PM
Turbinesaint's Avatar
Turbinesaint
Get a hockey puck and drill a hole in it. Mount the puck to the bottom of your jiffy stand. It will cost you about $5 to do. I use hockey pucks when I go camping or have to park it on grass, they work great.
Old Jan 7, 2016 | 06:13 PM
Stevos50nuts's Avatar
Stevos50nuts
I had the Bungking one on my FXR. No problems
Old Jan 8, 2016 | 11:01 AM
BigDogIdaho's Avatar
BigDogIdaho
This would probably be the easiest thing. You could use almost anything really with the same result.
Turbine, does it interfere with anything when retracted?
Old Jan 8, 2016 | 03:58 PM
Turbinesaint
I haven't had any issues with the hockey puck. You just have to check clearance prior to mounting.
handirifle
May 8, 2019 10:49 AM
666streetbob
Jun 25, 2016 03:54 PM
clap
Sep 22, 2014 06:52 PM
tazman509
May 8, 2010 07:22 AM
A-10 KChawg
Apr 30, 2009 11:13 PM
