Dual disk MC
Old Jan 19, 2016 | 03:52 PM
monster715's Avatar
monster715
Originally Posted by Odelay
Did the same as you are planning with no issues.
Cool good to know thanks!
Originally Posted by cggorman
Master cylinder plunger diameter is determined largely by total caliper piston diameters. Assuming the RK you used for the donor MC has dual calipers of the same piston count and diameter as your bike, you will be fine. If not, you'll want to consider the implications. The biggest effect is pedal/lever force required to actuate the brakes.
Good info thank you! The RK was dual disk and I believe were also 2 piston calipers but I don't know about the size of the Pistons. I know Harley changed to "Brembo" in '08 and the calipers changed but I don't know specifics about piston sizes. Worst case scenario I'll have to buy the correct MC down the road but it sounds like odelay hasn't had any issues. This conversion can add up when your running mags so since I already have the MC off one of my old bikes I'd like to try and save $120 if I could
Old Jan 19, 2016 | 10:40 PM
emerican19's Avatar
emerican19
You're golden. That's what I did on my old street Bob and it worked w/no issues.
Old Jan 20, 2016 | 09:34 AM
GVan's Avatar
GVan
Originally Posted by monster715
... I know Harley changed to "Brembo" in '08 and the calipers changed but I don't know specifics about piston sizes. Worst case scenario I'll have to buy the correct MC down the road but it sounds like odelay hasn't had any issues.
You're good to bolt on the Brembos down the road with the setup you are moving to. Same 11/16" MC running DOT4.
All I had to do when I put them on my '01 FXDXT (which already runs the 11/16" MC) was thoroughly flush all the DOT5 out of the system with denatured alcohol. (discussed in a few posts here).
wag_oh_neer
EVO
13
May 21, 2017 05:51 PM
agove
Jul 3, 2016 07:03 AM
HamToast
Feb 23, 2013 05:37 PM
JR-Boston
Jun 7, 2010 06:52 PM
frogg
May 31, 2009 01:30 AM
