Got the headlight brackets and Alloyboltz today...
Not sure who the original manufacturer is on these. They seem to be British based on my Googling. I got them from eBay from speedmotoco. They're nice anodized billet aluminum and appear to have stainless hardware. Not bad for $65. They fit the 49mm tubes perfectly.
Beautiful, as usual. Nice custom rear caliper pins.
Also got the TTIs the other day.
damn alloy boltz. I didnt know they existed when i bought the hardware for my engine rebuild. Wish i did. I guess i still could. Hmm
Their engine kit is great! It's packaged the same way. Everything clearly labeled and separated. I also like they are veteran owned. I put together a spreadsheet with all the bolts and the prices for different suppliers. Jegs is cheaper per bolt but you have to buy in increments of 5 so you often spend more on the bottom line and have a pile of extra (& expensive) bolts. I ordered some ARP stuff from Jegs but the vast majority came from Alloyboltz. I had to get the 2 big 1/2x2-3/4 riser bolts from Jegs because AB didn't have anything that big in their bulk bolt listings. Was like $35 for 5 bolts and I only need 2, so I may list the unused ones on ebay or something.
Originally Posted by SixDD
whatever they are - I hate them when they strip
Right! That's why I hate phillips.
agreed, that's why i'm a little pev'd, had no idea until WKNDS popped up with his kit
i bought garden-wescott and hd ...truth be told, it all cost less than $25(the bolt kits, not the other stuff) but, i'm still salty about the AB sets:
I don't mind Torx either, but c'mon... phillips worse than slotted?
For me, damaged slots are easier to repair, but severely damaged examples of either suck to remove. I replaced all my Mikuni screws with hex socket. All were slotted. I damaged several of the OE slots during teardown. I've read that the phillips profile was intentionally designed to limit applied torque by causing the bit to cam out. JIS cross is supposedly better, but I seldom work on equipment with JIS cross and don't have any JIS drivers.
For smallish screws (say #12 and under), I prefer Torx, hex/Allen, or square/Robertson. I seldom strip one (with hex being most common, mostly due to cheap drivers or fasteners) and the fasteners resist falling off the driver when working in recessed area.
