CGGorman's 99 Wide Glide build thread
Old May 6, 2018 | 09:20 AM
  #911
cggorman's Avatar
cggorman
Thank you.
I ordered some 1 mm "space gray" (and black, just in case) super high quality thread. Comes out of Germany, which I find odd for some reason. Supposed to be one of the nicest UV-stable braided poly threads available. I wanted something slick and shiny. The Tandy cords I was testing were OK but even the poly cord was a bit dull and coarse compared to what I had in mind. I'm over-thinking, I know, but it's my nature.
Ritza 25 "Tiger" thread...
Old May 13, 2018 | 04:01 PM
  #912
cggorman's Avatar
cggorman
Got the seat pan finished up and ready for foam.
Got the stitching all sorted.
Over the next couple days I'll glue up and shape the foam, then make the leather cutting pattern.
160 amps isn't nearly enough to fillet weld 1/4" aluminum plate. Would have been better off brazing it but whatever. Done now. The welds are embarrassing but they're solid as hell. They're hidden anyway, so I'm not worried about it.
Oh, and don't wear sneakers when welding... I got a real nice burn below my ankle where some slag fell into my shoe. Ouch.
Obligatory pics...
The burn...
Rivet holes chamfered, edges eased, top and bottom brushed and cleaned...
Nasty welds...
Back polished and Pete's medallion mounted...
Comparing threads and stitches...
This German cord is SO much nicer. I'm a happy camper...
Old May 13, 2018 | 10:18 PM
  #913
Krazy8s's Avatar
Krazy8s
That there is some nice work.
Here's a tip for your hand stitching, get yourself a resin block, (Tandy Leather or any decent crafts shop should have) and run your thread over it before stitching.
It will do 3 things for you.
1. Add to life and durability of the thread,
2. The resin sticks to itself as you stitch, so when stitches cross over the resin binds the the two stitches in place and holds them while you do the next stitch, so you don't have to continually go back a stitch or 2 and pull them taut again. HUGE timesaver.
3 Because the stitches bind to themselves, you don't need to keep the thread constantly taut as you go which will save your hands a lot pain.
Old May 13, 2018 | 10:31 PM
  #914
Krazy8s's Avatar
Krazy8s
Originally Posted by cggorman
Not digging the cream...maybe white would be better, but I think I'm gonna try to find a charcoal or grey. The whites are too much, I think.
I like the diamond stitch. REALLY strong but it takes a LOT of thread. Roughly 8x the seam length. The baseball is about 4x.
the white will look cream after a week of riding, road grime and your *** and legs against the stitching anyway.
Old May 13, 2018 | 10:45 PM
  #915
cggorman's Avatar
cggorman
Thanks for the tips. I do have a block of beeswax from Tandy. The thread I'm using is pre-waxed tho. It holds nice. Just sticky enough without picking up too much lint and loose leather fibers.
I'm going with the Space Gray Tiger thread. I didn't care for the cream color or the linen thread.
That gray sample I pictured was a quick and dirty trial. My holes weren't as nicely aligned as I'm capable. I just wanted to verify the thread choice.
I'm doing three layers of foam and I'm waiting a day or so between layers to let the cement set up. Once that's done I'll play with pattern making. Nothing fancy. I'm expecting 3 pieces.
Old May 13, 2018 | 11:05 PM
  #916
Krazy8s's Avatar
Krazy8s
Pre waxed threads are great, but the resin adds a little more tack to the thread and make stitching noticeably easier.
If you wanna get real creative, cut your leather pieces about an inch over size, skive the edges (i.e. take an insanely sharp knife and feather out the leather), then fold the edge and glue it down before making your holes. The edges will mate together better and look awesome. Plus there is more meat in the join and strength
If you're using 1 mm thread, the 3 mm multi tongue Awls you have are making too big a hole. See if you can get a 2mm or 1.5., or bump up to 2mm to 2.5mm thread.
Old May 13, 2018 | 11:15 PM
  #917
cggorman's Avatar
cggorman
Hmm...that's good stuff. Thanks.
I'm out of state right now (house sitting for family) but I'll see if I can find a place near here with leatherworking tools. I'm not super thrilled with the punching tools and don't want heavier thread so replacements sound like a good idea.
I was considering skiving the two side panels where they join fore and aft so I could do a flat felled stitch there. I hadn't considered skiving the whole thing. I may play with that.
The cross stitch is really secure and doesn't show hardly any of the cut edge but I do like the idea of a finished edge regardless.
Old May 14, 2018 | 08:15 PM
  #918
cggorman's Avatar
cggorman
Second layer of foam amd some rough shaping. I'll refine it by sanding tomorrow.
Sat on it for over half an hour and markedg the pressure points.
Trimmed and glued up.
Old May 14, 2018 | 08:56 PM
  #919
multihdrdr's Avatar
multihdrdr
Until I saw your "Cutouts", I thought you were drawing animal pictures
Old May 15, 2018 | 10:38 AM
  #920
Krazy8s's Avatar
Krazy8s
Ya gonna need another foam layer between the base and the one you cut out.
The cut outs you've made will let yer boney *** sit under pressure on the bottom layer, so you'll still end up with a sore ***.
Put a half thickness layer of foam that is a little more softer than the base and top layer, no cut outs.
Alternatively, Cut a new top layer, glue it down, then sand/grind out the pressure areas, limit the depth of the sanding to just above the base layer.
More laborious I know, but much better result in the end..... Pun intended.
