led light bar mounting
Old Apr 7, 2016 | 07:35 AM
666streetbob's Avatar
666streetbob
Default led light bar mounting
looking to install an led light bar on my triple tree, and i was just wondering how everyone has been mounting them and where they have been mounting the switch. any healp is greatly appreciated!!! this is the light bar that im looking into http://www.ebay.com/itm/2-x-18W-Floo...NW3l~e&vxp=mtr
Old Apr 7, 2016 | 07:51 AM
ajk511's Avatar
ajk511
That one you linked had a bracket on it with a stud. Remove that stud and just run the nut and bolt from your headlight through that bracket. Wiring the switch is a matter of preference. You can run it directly off the input to the headlight so it's always on. You can run it off the high beam switch, or you can run it back to the battery, with an in line fuse somewhere, and then run a switch wherever you want. Personally I would pull the tank panel an run the light off the ignition switch with an in line fuse and then drill a hole in the side of the panel to install a push button on/off switch. When it's back together it will look like the odometer switch on the older set ups..
Old Apr 7, 2016 | 01:44 PM
East_Coast_Dyna_Mike's Avatar
Hey man, I actually just made myself and a friend a set of brackets for our LEDs. I'll take a few pics and send them to you. I could make a set and send them.
Old Apr 7, 2016 | 02:23 PM
kyleMB's Avatar
kyleMB
If you have a bottom mount headlight just drill the bracket out to the same size as the bolt holding the headlight
Old Apr 7, 2016 | 02:25 PM
kyleMB's Avatar
kyleMB
Sorry for the giant pics, not sure how to resize them
Old Apr 7, 2016 | 02:40 PM
666streetbob
yea that'd be rad!
Old Apr 8, 2016 | 01:27 AM
PanHeadRich's Avatar
PanHeadRich
Just curious if these light bars actually serve a purpose? I've seen them on a few bikes but have no idea why. Is it to be seen better during the day, or do they serve as effective running lights at night? Do they offer any side lighting?
Old Apr 8, 2016 | 01:38 AM
Davdoodles's Avatar
Davdoodles
I mounted it to the headlight bolt, and wired it into the headlight's high beam circuit (inside the headlight shell for neatness, with an in-line fuse for just-in-case).
I only use it at night on dark Australian backroads (basically as a super-high beam/spotlight), so wiring it that way is fine for me.
"Do they offer any side lighting?"
The most common ones I've seen (a six LED unit) comes in both "spot" and "flood" varieties. The spot (mine) doesn't give much side lighting but it is lighter than the standard HD high beam. I'm guessing the floodlight variety will give more side lighting but substantially less distance down the road ahead...
Old Apr 8, 2016 | 06:32 AM
Warp Factor's Avatar
Warp Factor
Much increased visibility during the day, and very bright from an off-angle, where the brightness from the headlight almost disappears during the day.
I have mine directly wired to the highbeam circuit, no separate switch, leads attached inside the headlight bucket. Huge increase in highbeam brightness at night too. Way too bright to use at night except has a highbeam, when there aren't other vehicles around.
Old Apr 8, 2016 | 08:37 AM
kyleMB's Avatar
kyleMB
I've got mine wired to be on all the time. Its amazing how much you really notice on the sides of the road and such once you install one
