Brake pads
Old Jun 6, 2016 | 11:24 AM
HKMark23's Avatar
HKMark23
Originally Posted by HD Bobber
Can't go wrong w/ EBC & Lyndall pads! I'm running the Lyndall Gold+ front and back w/ awesome results. I paired them w/ EBC Contour Cut rotors as well.
Also, wanted to note that I ran the pads for couple thousand on stock rotors before I added the new rotors.
Wound up with the Lyndall Gold + pads myself.
Old Jun 6, 2016 | 11:50 AM
TinCupChalice's Avatar
TinCupChalice
Running the Gold+ here as well. I ran the Z+ pads since the bike was brand new, I tossed the stock pads almost immediately; I was never a big fan of sintered brake pads. I know the sintered pads give a better initial bite as you apply the brake but the composite Lyndall pads have a smooth progressive feel to them and I'm able to more effectively modulate the brake under threshold braking. Some like the more aggressive initial bite of the sintered pads but I like how accurately I can control braking with the Lyndall composite/kevlar pads.
This is a good read comparing sintered to composite brake pads HERE
Old Jun 6, 2016 | 01:44 PM
F86's Avatar
F86
My rear brake is the stock HD caliper with a fresh HD floating rotor, EBS HH pads, and a Goodridge braided line. It works very nicely.
Old Jun 6, 2016 | 02:24 PM
cggorman's Avatar
cggorman
I hate how so many vehicles come stock with brake calibrations that grab hard initially but have little to offer beyond that. I understand the mass consumer preference for the impression of power and how it inspires confidence, but I feel it's misguided. I much prefer the linear feel of a friction material that takes a little distance to ramp up.
Old Jun 6, 2016 | 02:30 PM
F86's Avatar
F86
This is exactly how most domestic and Asian passenger car braking systems are designed... Strong initial bite, very little ability to hold up to threshold braking in emergency stops. Lots of OEM systems are designed to cater to the things they think consumers want. In this country that means initial bite, low noise, long life... Often at the expense of fade resistance.
Old Jun 6, 2016 | 03:31 PM
TinCupChalice
You are both right on the mark. I've seen the differences in my stopping distances between sintered and organic/composite brake pads. The sintered pads come on hard but you can't find that line as easily between kinetic friction of a rotating wheel/tire and the static friction of a sliding wheel/tire. You end up using the brake lever more as an on/off switch.
With the organic/composites there's a feel of where the edge is allowing you to modulate the lever to keep that front rotating yet getting maximum braking at the limits of your tire traction.
rufasim
May 2, 2015 08:27 PM
spider2
27
Nov 22, 2012 05:09 PM
South Jersey Scooter Trash
Apr 1, 2012 07:30 AM
HDV-GLIDE
Feb 24, 2012 02:15 PM
vet767
Apr 9, 2009 07:53 AM
