clunk from front end
Old Jun 7, 2016 | 02:42 PM
emperor wurm's Avatar
emperor wurm
Originally Posted by nevil
When you use the front brake the bike transfers weight forward. A worn mount can make the motor shift and contact a part that is not rubber mounted.
Ill check it out tonight, Thanks!
Old Jun 7, 2016 | 03:02 PM
TinCupChalice's Avatar
TinCupChalice
If you plan on inspecting your front isolator give the 16 May 2012 M1324 Service Bulletin a look and check the top radius clearance on the isolator. That service bulletin was issued due to Dyna vibration problems but if an isolator is failing it begins to distort and can end up contacting the engine bracket. If you don't have any clearance that will be another indicator of a front isolator failure.
Old Jun 7, 2016 | 04:36 PM
crzoomb's Avatar
crzoomb
Old Jun 8, 2016 | 07:12 AM
MORT666's Avatar
MORT666
He of little faith junk the lock washer crank the top nut up and the clunk will go.
Old Jun 8, 2016 | 07:17 AM
Scudda's Avatar
Scudda
I had this issue on my Fat Boy and it ended up being a broken fork pinch bolt
Old May 31, 2024 | 12:34 AM
Charlie522's Avatar
Charlie522
Stage I
Default Clunking in front end of dyna when bumps hit or braking with front brake. Check your front engine mount, the rubber has probably deteriorated. My 2016 Switchback had the same problem $180.00 and half hour labour's and no more noise.
Originally Posted by emperor wurm
Does anyone else have a clunk from the front end when going over bumps? I checked my gas tank, all the front end bolts, steering stem nut and everything is tight. I get a clunk or clack sound when i hit bumps. it sounds like the front right fork. I have installed a set of progressive HD springs, but they have been on for over 2000 miles and i didnt get the noise after installation. this started happening about 500 miles ago. any ideas?
check your front engine mount. My 2016 Switchback had same issue. Clunking noise in front end if I was braking with front brake or going over a bump. You can look and you will see engine casting is resting on top of mount. The rubber has deteriorated or split. The part is about $180.00cnd from Drag Specialties
Old May 31, 2024 | 09:12 PM
Redbeard's Avatar
Redbeard
Originally Posted by 1HD1C
gas tank bolts/nuts did you use a torque wrench or just tighten them down?
if you just snugged them get a torque wrench on them to specs
(old thread but still relevant)
I had a clunk over bumps on my 2011 WG and checked that everything was torqued properly according to my service manual, yet the clunk persisted. After reading multiple threads where many folks mentioned gas tank bolts were the most common culprit, I decided to to add a couple more ft/lbs (up to 22 from 20 I think) to mine and the noise went away.
I don't know if that means the spec in the manual is too low or my torque wrench is off, but the point is to double (or triple) check the fuel tank bolts because that seems to be the issue for a lot of the front end clunks.
gleam
Sep 15, 2018 04:58 PM
Alain
Aug 19, 2013 05:53 AM
bobbyjoes
Jul 7, 2012 03:04 PM
JollyRogers
Oct 11, 2008 07:10 PM
KBFXDLI
Oct 8, 2007 07:29 PM
