Clunking clutch
Old May 19, 2007 | 08:46 PM
dan69co's Avatar
dan69co
Default Clunking clutch
Anyone had this symptom. Went for a ride today and probably put 20 mi. or so on. Upon returning home I noticed that the primary made a clunking noise whenever I would release the clutch. I serviced this a couple of days ago and replaced primary oil with formula plus oil(32 0z). I have ridden it probably three or four times since the service and it shifted very smoothly. Clutch does no slip just clunks. I have checked to make sure that there was no leak under bike. Can anyone tell me whats going on with this? Thanks in advance.
Old May 19, 2007 | 09:43 PM
dan69co's Avatar
dan69co
Default RE: Clunking clutch
Also checked to make sure ther is oil in primary.Manual says hard shifting caused by too much oil. Drained out maybe 2oz. Test drove and still has small clunk when clutch is engaged. Could it be that the formula plus is causing this. What type oil is in the primary from factory?
Old May 19, 2007 | 09:47 PM
BlueBob's Avatar
BlueBob
Change to 85/140 gear oil.
Old May 19, 2007 | 10:04 PM
dan69co's Avatar
dan69co
Manual says use only formula plus. If its gonna make that much noise and shift hard that stuff will not stay in there long.
Old May 19, 2007 | 10:05 PM
dracos's Avatar
dracos
my bike is an 06 Wide Glide and it does that clunking all the time when you release the clutch. I don't pay much attention to it anymore. I run Mobile 1 synthetic, but it has made that noise ever since I've had it. I have about 8000 miles on it and the clutch works fine.
Old May 19, 2007 | 10:11 PM
dan69co's Avatar
dan69co
Clutch works fine, just shifts hard and clunks. Annoying. Maybe I just didnt notice it before and am being paranoid.
Old May 19, 2007 | 11:01 PM
HD7585's Avatar
HD7585
85/140 is transmission lube..........not for primary..........20w 40 synthetic is the ticket
ORIGINAL: BlueBob
Old May 20, 2007 | 02:02 PM
BlueBob's Avatar
BlueBob
ORIGINAL: HD7585
ORIGINAL: BlueBob
OOPS! Your right....
Midpegs
Jun 5, 2019 09:52 AM
Scrubdog
EVO
Sep 19, 2012 09:46 PM
aoehero
Oil Archive (no new posts)
Jun 16, 2011 09:44 PM
57_kid
Apr 9, 2009 04:07 PM
Howard
Aug 4, 2006 06:29 PM
