Hi dudes, I've had my 2014 FXDB for about 10 days now. Only has about 4500 miles on it. I rode the bike totally stock during that time to get a feel for the engine and just completed all my stage 1 mods in one day yesterday.
I've never owned an EFI Harley before this one and have a few questions:
1) I don't know how else to describe this, but when I take my hand off the throttle, it seems to decelerate/lose momentum WAY faster than my carbed Dyna. Normal?
2) Seems to be a lot more vibration on decel. It's also a noticeably different sort of vibration than at idle or acceleration.
3) Is it possible to have a "dead spot" on the RPM range? The bike seems to hiccup/stutter/flatten out at 2600 RPM no matter what gear I'm in. Problem is that I am often cruising near that number so it's weirdly noticeable.
I installed the Power Vision last night and although the bike is night and day different (BETTER) in every other aspect with the PV, these 3 issues persist. Just looking for some feedback as to whether these are common or not. Thanks!
I selected a Dynojet Pre-configured tune for my setup. I chose the closest tune for what I have (2-1, high perf intake) and she runs pretty well with that tune, despite the issues I mentioned in the OP. In the video, he is using the autotune feature on top of the original tune, i.e. the one set from the factory that I am no longer running.
Should I start by running the Autotune on top of the pre-configured tune I'm currently using (not factory original)? And each time I run Autotune, do I run the next session on top of the previous session (i.e. use the same slot)?
I would, yes.
Yes again.
I would:
Autotune the one you chose.
When done with the ride save/export the tune you just AT'd.
Suede Blue Man has you covered but a few more tricks: be sure the bike is fully warmed up before you begin an auto tune run. The bike will run poorly during the run so don't be surprised. If you can, mount the PV on your bars and monitor the run, watch the cells fill with data. They'll go from green to a yellow/orange, then to red when they max out. Try and adjust your riding to fill as many of the cells red as you can.
When you're done with the run don't use the ignition, shut down the bike with the kill switch and leave the ignition on. Stop the auto tune, save the new tune and export the new tune before you turn off the ignition.
you should not have any dead spots or hiccups with stage 1 efi bike.
i would try a couple auto tune runs.
I have a '14 lowrider with stage 1 air cleaner, slip on stage 1 muffler (with cat) and power vision and it runs smooth and consistent. My tune was loaded by the people i bought the tuner from, FUEL MOTO.
I hope to try the auto tune myself soon, thinking of removing the cat and adjusting it with the auto tune.
good luck
Reason: forgot stuff
