dyna wide glide front peg relocation question
Old Jul 10, 2016 | 04:40 PM
user 8382390's Avatar
user 8382390
Default My solution
I too was bothered by the knee hugging. I bought kuryakin iso pegs and some extensions that made them go out another inch. Not expensive and gave me the extra room I wanted without sacrificing too much lean angle. Capped it off with matching iso grips
Old Jul 10, 2016 | 04:45 PM
Clayjenson's Avatar
Clayjenson
I have forward controls stock and put mid pegs on as well. They're folded up most of the time. I have a DK air cleaner and used the stock cover. I used the bracket from football cover and shifted it a hole farther forward. End result, it looks stock but forward maybe an inch. Clears the knee better. No problem with horn side for me.
Old Jul 11, 2016 | 10:14 AM
user 7172984932's Avatar
user 7172984932
I did the same thing. New pegs, shift lever, brake pad from Kuryakyn. Also changed grips. Ordered through Amazon. Couldn't be happier
Here's the model #s
8025 one inch extended large ISO pegs
8021 longhorn ISO shift peg
8044 brake pedal pad
Don't have model # for ISO grips. But you can look at website
Old Jul 11, 2016 | 10:25 AM
user 7172984932
Here's model # for Kuryakyn Grips with dual cable throttle control
6205 (chrome)
6320 (black)
Old Jul 11, 2016 | 04:53 PM
gustrider4's Avatar
gustrider4
6th Gear
Thanks for the part numbers. I actually ran the same kit on the sportster
Old Jul 11, 2016 | 06:37 PM
saddlebag's Avatar
saddlebag
Originally Posted by gustrider4
Hello everyone, I just picked up this 2014 wide glide yesturday and love everything about it. The only thing is im a little on the short side, so my legs rub up on the air filter on the right side and the horn on the left side. Is there a kit out there that could kick the pegs out to the side and/or closer to the back? thanks.
I have the same problem. On previous cruisers, I've either had or added floorboards. The Switchback floorboards are sold as a kit, but won't fit the WG with the stock exhaust.
I got the chance to sit on a WG with the fold out heel rest footpegs. That felt really good and allowed my leg to sit further from the air cleaner comfortably. I think the ideal solution would be to put one of those Screamin Eagle Heavy Breather intakes. That would provide a clear path to the peg.
Old Jul 11, 2016 | 09:10 PM
gustrider4's Avatar
gustrider4
6th Gear
Waiting on the new v&h pipes and the screamin eagle breather to come into dealer for install. the stock breather is pretty big and bulky
USAF_IYAAYAS
Jun 24, 2012 02:44 PM
C908
Nov 10, 2009 09:54 AM
mikecdmd
Jun 12, 2009 07:09 AM
stewie
Mar 28, 2007 02:08 AM
hoggsbreath
Feb 6, 2006 11:48 PM
