Lazarus Project: 2012
Old Jul 24, 2017 | 11:24 AM
  #921
cvaria's Avatar
cvaria
Hard lessons and fun.
While i was riding the bike to home depot, i had the demon and angel on my shoulders. The demons like, "build more... add more ****". Angel was like, this is good.... you are bounds above where the 103 was, leave it alone."
swatted angel off...
Now trying to get an appointment with doc's.
Old Jul 24, 2017 | 11:35 AM
  #922
cggorman's Avatar
cggorman
Do I hear the words titanium and inconel in your future?
Old Jul 24, 2017 | 11:53 AM
  #923
cvaria's Avatar
cvaria
not sure, there a free 2012 ninja 250 project i was offered. I went to get it last week and was stunned by the condition of the bike. I backed off of it but, the guy is now begging me to take the free motorcycle. That might be my set of sport bike training wheels. Needs about $1200 in parts and new tires. Seems like fun but, new lifts and blah... weighing it out.
Old Jul 24, 2017 | 02:06 PM
  #924
TinCupChalice's Avatar
TinCupChalice
cvaria, you absolutely MUST do this! I love the little Ninjettes, they're easy to work on and mod, and they are the bikes I always recommend to new riders or riders new to sport bikes. I've owned 2 of the Gen IV Ninja 250's; they were both '12's. A few simple mods and these things will run out well.
They're a great training tool; you'll learn how to carry corner speed using technique, you won't be able to rely on horsepower. People that start out on a small bike and learn proper techniques are always the fast one's at the track when they move up in displacement.
Maintenance isn't difficult, and keeping the valves adjusted isn't at all hard to do. eBay always has a flow of parts on it. With my '12's I tore out the restrictive air boxes so I could fit K&N air filters, removed the pair systems, used Area P exhausts, set up the carbs with Dynojet kits, and used Pirelli Sport Demon tires. Those little quarter bores would scream and I pushed them like they owed me money, and they just came back for more
The only thing I didn't like about them were the oil filters; they still had the cartridge oil filter, it was the Gen V/Ninja 300 when they went to a spin on oil filter. Rumor has it Kawi is going to bump the Ninja 300 up to a 400 in '18; if they keep the weight of the bike the same that little thing will scoot.
Remember, it's more fun to ride a slow bike fast, than a fast bike slow
Old Jul 24, 2017 | 02:53 PM
  #925
cvaria's Avatar
cvaria
That thing needs work... serious work. New fairings, gas tank... all kindsa ish.
you are right. All cheap parts and damn near every bit of them are on ebay. Have the service manual already... just mentally fighting it. That thing is jacked up.
Old Jul 24, 2017 | 03:09 PM
  #926
TinCupChalice
Oy, you're looking at a binned bike, apparently The parts are on eBay if it's a job you want to tackle. They are easy to work on, but when they take a tumble without a decent set of sliders bad things happen to them.
I do understand the hesitation now, I'm not a fan of putting a bike someone tossed out in the tall grass in my garage either But honestly, it's a great introduction to sport bikes... and... it's free.
If you did decide not to put her back in to proper order you could part her out and make a few bux to fund your next Wide Glide upgrades... jus' sayin'...
Old Jul 24, 2017 | 09:18 PM
  #927
cvaria's Avatar
cvaria
Default Injectors, B.A.A.C., Throttle body, and manifold...
updated the tune with injector size and just to double check... asked if needed to update anything else in the tune and got everything but a yes or no.
A: https://www.hdforums.com/forum/ignit...ttle-body.html
B: https://www.hdforums.com/forum/engin...ttle-body.html
moved on:
loaded the tune.
pulled of the the old goods and added:
  • Big *** Air Cleaner - S&S STEALTH AIR CLEANER 58MM 170-0164
  • Bigger *** Filter - S&S Cycle High Flow Air Filter Kit 170-0127
  • Big *** Rain Sock - S&S NYLON PRE-FILTER FOR HARLEY WITH S&S STEALTH AIR CLEANER 1" TALLER HEIGHT 170-0197
  • SE Pro High-flow Injector Kit 4.9 injectors (SE 5.3's are meant for the 58mm ETC throttle body) 27797-07
  • SE 58mm-62mm manifold 29667-07
  • SE Pro High-Flow 58mm EFI Throttle Body - Cable Operated Throttle - 27639-07B
old boy.
so glad i bought a ratcheting wrench set.
manifold on
tb on
f'd upbackplate with test fitted hoses
good
good.
super stand-offs
done
out for the test ride
File Type: csv
File Type: txt
Old Jul 24, 2017 | 09:36 PM
  #928
cvaria's Avatar
cvaria
bike started right up, no problems.
took it out for an auto-tune run. felt angrier but, that could all be in my head. noticed some hesitation but, talked to the dealer earlier in the day. they said they'd give it a courtesy tweaking on friday. fair enough. still going to doc's.
everything felt good EXCEPT that BIG *** AIR CLEANER! rubs my knee when braking. if my pedals were not out so far, this would be a deal breaker. it's now hard to reach the brake pedal. need an extension. i now get the why the new breed of air cleaners look the way they do.
i.e.
Old Jul 24, 2017 | 09:40 PM
  #929
Nemosengineer's Avatar
Nemosengineer
Civera,
Don't do it. You already are a motorcyclist and you have good judgment, and to add to this, you're a horsepower junky. You will be bored 2 hours after you get that pile put back together. Remember motorcyclings golden rule, whatever you think it will cost double it and you're in the ballpark.
Get Keith Codes book "Soft Science of Roadracing Motorcycles", and read it four or five times, it covers all the bases.
Go find a nice 600 class sportbike and discover how the other half lives .
Don't forget to look at one of these... This is a 2006 Triumph Daytona 675R, do a bit of research and you'll see why I mention this bike.
: Mike
Old Jul 25, 2017 | 07:39 AM
  #930
cvaria's Avatar
cvaria
Originally Posted by Nemosengineer
Civera,
: Mike
mathematically, by the time i'd get finished rebuilding the pile of bike, i'd have spent the same amount to just buy one used. they go for $1500-2500
the difference /advantage is that i would have built the pile and know it backwards and forwards vs not knowing what's going on under the fairings of some other bike.
